SOURCE: boss bv9557 will not power on
You may not have connected the hot lead of the player to the correct 12 volt accesory source. If you connected to the lighter plug, the ignition key needs to be turned to "run" for most of those to work these days.
If you tapped the wires for the door switch for couresy lights, you need to pick a different ground wire connection and power feed. the door switch is usually a grounding switch for the courtesy lights which have no ground until that switch closes contact with an opening. door. The power you could draw from that circuit is minimal because the courtesy lights are in series with that player - if connected in that manner.
