Question about Black & Decker String Trimmer Cordless 12" 18V
Replacement spool for line trimmer WS500 Type 2.
I own a WS500 Line trimmer type 2. I wanted a replacement spool of line and found the parts I wanted at a local store. However once I looked at the parts, they don,t fit this model of trimmer even though they say on the bag that they fit a WS500. All I want is the spool of nylon line. What do I ask my local store to order, if they don't stock the spool of nylon line?
  • 313 Answers
SOURCE: Can't find spool replacement AF-150-04
not sure but .065 maybe
Posted on Jul 09, 2008
SOURCE: grasshogXP string trimmer GH1000-ca type 2 7.2 amps
You can order replacement parts from:
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/blackdecker/CST2000_TYPE_1
Posted on Jul 14, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
  • 4 Answers
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Posted on Aug 07, 2008
  • 207 Answers
SOURCE: The motor is working but
Does the trimmer head spin freely? If so then it is somehow disconnected from the motor. There should be a motor coupler somewhere near the motor and also near the trimming head. Make sure they are connected.
Posted on Jun 06, 2011
The line that I'm looking for came as stock supplied when I bought the trimmer.I can't believe that Bolens doesn't have a scource for replacement line. Help. Gene
Genuine MTD 791 181460B Reel Line Assy McCulloch Ryobi Troy Bilt Bolens OEM
Reel and Line Assembly
Bolens String Trimmer Spool 791 153577B
the spools come with line already installed,they are all for bolens,line is generic,you buy your own line,there are 2 different sizes,and a bunch of types,like round or star,you buy generic line because bolens wont make any money if they sold "BOLENS" line.
Jul 11, 2015 | Garden
Replace line
Two possibilities:
1. Buy a new spool. Make sure you bring your make and model/size to the store to get the correct replacement spool, or
2. Buy new line and manually wind it into the existing spool. Smaller lawn trimmers and edgers use smaller diameter line than larger lawn trimmers and edgers.
Good luck.
Paul
May 31, 2015 | Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
Pope renegade 28 cc line trimmer cord replacement
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ``
Jan 22, 2012 | Garden
Just bought a TE475. can't figure out how to replace the line compared to the traditional one-line configuration I am used to
Here is the info from the manual, the replacement line is put in near the center of the spool on the top of it, you simply feed it in. I have included a link to the manual so you can see the pictures. Look at page 10 for these instructions.
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spoo
Aug 25, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I don't know how to restring the weed eater
LINE REPLACEMENT Pre--wound spools offer the most convenient method for replacing line and ensuring optimum performance. S Replacement spools are color--coded to ensure use of the correct spool with your unit. Be sure to use the same color spool as the existing spool. NOTE: Always clear dirt and debris from cutting head components when performing any type of maintenance. S Hold spool and unscrew cap by turning in the direction shown on top of the cap. S Remove line guide ring and spool. NOTE:When removing and/or installing spool, ensure dust cup remains installed over shaft. Use a pre--wound spool or refill spool with line. If using a pre--wound spool, remove tape strip from line and spool. REFILLING THE SPOOL WITH LINE WARNING: Use only 0.080" (2 mm) diameter round line. Other sizes and shapes of line will not advance properly and will result in improper cutting head function or can cause serious injury. Do not use other materials such as wire, string, rope, etc. Wire can break off during cutting and become a dangerous missile that can cause serious injury. 1. Cut a length of 25 feet of 0.080" (2 mm) diameter round WEED EATER brand line. Feed line in direction shown on spool. Spool 2. Insert one end of line into center cavity of empty spool. Ensure line will feed into spool in the direction shown on the spool (counterclockwise). 3. Continue feeding line into spool, leaving 4 -- 6 inches (10 -- 15 cm) unwound from center of spool
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have the Cub Cadet CC4125. The head for the line is very wasteful.Line will not stay in the spool. I also have Toro with the spool type head on it,and this is more efficicnt. Does Cub Cadet have a spool...
If the head is shot, go to Home Depot and in the garden center, you will find many replacement type heads. They may have one that will fit your machine, because they carry universal replacement string heads. Check them out because they are cheaper than the small engine repair shop.
May 26, 2011 | Garden
How do you add trimmer line to Troy Bilt TB539E Weed Eater?
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
Sep 07, 2009 | Garden
Black & Decker String Trimmer Cordless 12" 18V Logo
452 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
