Question about Amana Refrigerators
I have AMANA Model 12799423LT. Display is flashing and ice door is opening and slamming shut.
SOURCE:
SOURCE: fridge display
the high voltage baord is bad. order part # 12920710 and replace.
Posted on Apr 19, 2007
SOURCE: hv main control boadrd
I had the same problem, fixed it myself with <$20 in parts from Radio Shack ( <$5 if you have soldering equipment, or know someone who does) .  My step by step instructions at http://www.liny.net/MaytagIce2O.htm   Good luck with it.
Posted on Oct 28, 2007
aborcass
  • 2651 Answers
SOURCE: Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Posted on Mar 12, 2008
  • 244 Answers
SOURCE: garage door slamming shut
springs are shot/wrong. door not balalnced.
Posted on Jan 15, 2009
jpk528
  • 95 Answers
SOURCE: 2005 Chevy Tahoe back door won't stay open...slams shut
no you probably have to change the lift gate struts/supports that are on the liftgate itself. very easy to do and they sell them at the autoparts store i would say for around 30-60 bucks
Posted on Feb 16, 2009
Ice dispenser door keeps opening and closing and no water or ice will dispense and the temperature displays keep,flashing
what is the model number. But if my guess is correct you have a main board failure. few years back Amana had a recall to replace the main board on this unit. customer complaint about unit acting like it was posses
Dec 21, 2014 | Amana Refrigerators
I push handal on door and does not make ice motor run got plenty of ice no blockage handal operates shut and open lid seal in door ice throat
pull out the ice bycket,you'll see a metal piece that connects to the auger motor,if you see ice there heat it up with a hair dryer the motor could be frozen or the auger motor is bad,send the model number,also open the door,remove the ice bucket,hold in the door switch and push on the part to let the ice come out,do you hear a humming sound or can you hear the motor run,if not bad auger motor.
Sep 11, 2014 | Amana 22.6 cu. ft. Side-By-Side...
Door slams open Maytag Fridge MZD2766
Human error may have resulted in the hinges being installed incorrectly. To confirm your suspicion, check a similar Maytag on display in a store.
May 26, 2017 | Maytag MFD2561HE Bottom Freezer French...
Amana freezer door doesn't fully shut
There is a drain inside the freezer part of the arb2257csr. The drain can get clogged and the water from the defrost process will pool up on the bottom of the freezer. You can gain access to the back of the unit and remove the pan drain to clean it out. Then make sure water flows and ice is not blocking the drain. It takes a long time to melt so I used a turkey baster and put hot water into the drain from the lower inside middle of the freezer. This drain pan can get pretty smelly when rancid oils and such don't evaporate the way it was designed to evaporate the water. The symptoms were ice on the inside bottom and water pooling in the front of the drawer. It also became very hard to close the door due to the frozen door slide. I have not seen anyone report this on any site so far. Everyone talks about the thermostat but no one seems to have arteriosclerosis of the drain tube.
Apr 15, 2013 | Amana Refrigerators
Hi, I have a amana af12538aes french door refrig. Starting this am, the control on the door does not deliver ice only cold water from the ice button. The ice maker is making ice. Is this a control...
Is the display flashing when you try and use it or can you hear the dispenser door opening and closing rapidly (clicking or clapping sound)? These are prone to the board going bad and losing the dispenser. Is the "ice" light lit on the dispenser? The touch pad could be bad too. Do you hear the auger motor turning the ice when you press the dispenser? or just the "shhhhhhh" of the water coming out?
If there is ice in the bucket then that is not the problem. Dump it and listen if you hear new ice drop to verify.
There is no such part called an "ice element". Ice maker-yes.. Heating element-yes.. Ice dispenser-yes
Mar 04, 2018 | Amana AFD2535DES French Door Refrigerator
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Garage door slamming shut
Sep 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Refrigerators Logo
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
