Question about Sewing Machines
Bernina 930 My Bernina suddenly started sewing backwards - I can hold the forward/reverse knob down with pressure to make it go forward, but if you let go, it starts sewing backwards. It's almost like something let go inside that would hold the forward in place.Any suggestions?Paula
  • Sewing Machines Master
  • 11,769 Answers
Have you ever done a thorough internal oil of your machine? These mechanical machines rely on oil to keep moving but, over time, that oil dries and starts to stick things together. I do a deep internal oil about annually and oil the hook at least every 8 hours of sewing.
Wheel on right side that controls the needle up and down is very tight...
There's an oil diagram in this answer:
http://www.fixya.com/support/t26371053-am_looking_bernina_930_service_manual
How do you open bernina 930 sewing machine especially removing the side...
Posted on Feb 24, 2018
  • 82 Answers
SOURCE: sewing backwards
Yes, this is a problem that a trained Viking repairman needs to resolve. It might need to have the zero feed position adjusted.
Posted on Jan 20, 2008
bilabon
  • 46 Answers
SOURCE: Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Posted on Jul 29, 2008
  • 21 Answers
SOURCE: Bernina 1630 problem
Your feed dogs sound like they are getting stuck,chec whether they are on the down position,and also make sure that you have cleaned any lint that builds up in the bobbin area, if all fails it will have to go into the technician,
Posted on Sep 21, 2008
mohammed387
  • 1952 Answers
SOURCE: Bernina 1090 only sewing backwards
1.Turn the bobbin winder off.
2.You have to reverse the wires on the carbon brushes.
3.Make sure that you have the needle in correctly- with the flat side to the back. Those machines rarely go out of time.
Posted on Jul 22, 2009
calmeblondy
  • 33 Answers
SOURCE: my bernina artista 180 is stuck in reverse and
unscrew lever a bit and lower to stitch forward
Posted on Sep 28, 2009
Bernina 1010 reverse knob is stuck in the up position. Only sews backwards.
It's an older mechanical, right? Most likely it has seized due to old oil that has dried.
I've used the following method on a seized 930 and it is purring away now.
Sep 27, 2017 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
Mar 10, 2011 | Bernina Activa 140
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
Jul 22, 2009 | Bernina Sewing Machines
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
