Question about Logitech Attack 3 Joystick
Manual for AV8R-01
I d like to get the manual
I have changed my operating system from XP home to Windows Home Premium. my Saitek AV8R-01 seems to be designed for XP. Can I intall a driver that will work with Windows 7
The driver for Windows 7 can be downloaded from here:
http://saitek.com/uk/down/drivers.php
From the second drop-down menu to the right select Joysticks then select AV8R and then select your operating system.
You'll have 2 buttons with the driver and software. Click on each and save the driver to your computer then install them(driver first).
Hope it helps. AV8R AAV8R
Apr 26, 2011 | Saitek Aviator AV8R Joystick
Hi;How do restore the calibration screen for the Saitek AV8R-01. I have a Microsoft Windows XP.
You can use Clear Calibration Utility, which will help you get rid of all the calibration data.
32bit version: http://www.wingmanteam.com/files/Tools/ClrCalib/x86/ClrCalib.exe
64bit version: http://www.wingmanteam.com/files/Tools/ClrCalib/x64/ClrCalib64.exe
Readme: http://www.wingmanteam.com/files/Tools/ClrCalib/Readme.txt
Apr 20, 2010 | Saitek Aviator AV8R Joystick
Saitek AV8R-01 Joystick - How to install?
No download disk is required. Your PC will automatically 'find' the joystick after it has been plugged into a USB port.
You can just about play any flight sim with this joystick, jat, prop plane or helicopter. The buttons do what ever you program them to do through your game's control settings.
Mar 19, 2009 | Saitek Aviator AV8R Joystick
AV8R manual
Got to www.saitek.com and download the relevant manual
Mar 15, 2009 | Saitek Aviator AV8R Joystick
Joystick turned off, won`t operate
Ok... that is a VERY Easy fix... all you do is get into a plane with the kneeboard and click controls and find it!
Feb 09, 2009 | Saitek Aviator AV8R Joystick
Windows 98 drivers for Saitek AV8R joystick
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Jan 25, 2009 | Saitek Aviator AV8R Joystick
Use of AV8R-01 with Google Maps flight simulator
My blackwidow joystick would not work in google earth, the sim would just crash. I tried a surgestion to remove the blackwidow software and just run it with the ms hid driver. It now works fine, even the throtle and rudder controls.
Dec 27, 2008 | Saitek Aviator AV8R Joystick
Saitek aviator joystick av8r-01
Well.. if you have windows xp.. then you can calibrate your controller fairly easily.
Go here:
Control panel:Printers and Other Hardware:Game Controllers:(your controller should be in the list):Advanced:Calibrate
This should solve your problem ;)
Apr 11, 2008 | Saitek Aviator AV8R Joystick
Logitech Attack 3 Joystick Logo
215 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Ekse
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
