Question about Refrigerators
Fridge is not cold - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 21,178 Answers
Thats just terrible
Posted on Aug 20, 2018
Fridge Freezer not cold
Is there a fan inside the freezer compartment to direct cold air to the fridge? Check it's working. If not fanned, check rear wall of fridge. If not cold, unit may be short of gas.
Apr 20, 2014 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Refrigerators Logo
676 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
