Scales turn but screen shows offset reading.
BF-679W/BF-680W - Tanita
Tanita
https://www.tanita.com > .downloads > download
PDF
This Body Fat. Monitor/Scale passes a low-level electrical signal through the body, which may interfere with the operation of a pacemaker. • The Tanita Body Fat ...
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
SOURCE: when i turn on my digiweigh dw 100ax scales F--H
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
SOURCE: My bathroom scales ww35cha stopped working, i
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
[email protected]
SOURCE: How do you adjust the tanita 1479 scales
what do you mean by adjust it? to calibrate it follow below
Switch off.
2. Press and hold OFF key.
3. Quickly press ON/ZERO key three times then release both keys together. The timing is rather critical, so if it doesn’t work first time, try again.
4. Display shows [ 0.-0- ], followed by [ 0.-1- ].
5. Place 50gm weight on plate.
6. Display shows [ 0.-2- ].
7. Place 100gm on plate.
8. Display reverts to weighing mode.
Testimonial: "Yes you were correct i did mean recalibrate it worked 100% many thanks in deed."
