Question about Toshiba Qosmio G15 Notebook
RE: Tea spilled on Toshiba Qosmio G15 Keyboard
Saved computer, everything boots, starts and runs with no problems via mouse - keyboard just doesn't fully respond - and I get like 6 beeps when the computer does start up. I figured it is the keyboard issue. So - Found a new keyboard i can order for 41 - 49 bucks and just not sure how to change it out. I did see where it connects to the computer - via some slim tape wiring with what looks like a small parallel port connection - something like that anyway. Just wondering how hard it is to change a keyboard out on this model, anyone? Thanks so much, Allen
  • 116 Answers
Re: RE: Tea spilled on Toshiba Qosmio G15 Keyboard
Simple swap! You need to turn over the PC, Locate all of the screws on the back, most of them will be identified by a circle with a K in the middle for Keyboard. Unscrew all of those screws, becertain to get them all. Once you have done that make certain to carefully remove the keyboard. The keyboard is attached to one connection that snaps into the mother board so do not pull too hard on the keyboard! It is that simple!
Posted on Nov 26, 2007
0 characters
3 Points
I spilled I tea on my Gateway FX keyboard and mousepad. The keys are working now but I'm worried they will get sticky. I cleaned up as much as possible by patting with a towel to soak up the tea. ...
Before you do anything, unless it is already dried, (turn it off first!) turn the laptop upside down and gently tap the back to coax any liquid out. Then do NOT turn it on until it is totally dried. You can clean the keys and pad it with a DAMP (NOT wet) cloth with plain soap and water. Be careful not to get any water down into the keyboard itself so it doesn't short it out. However this will not clean whatever liquid may have gone inside. Hopefully none did else you could end up with a bigger problem...
Jul 16, 2011 | Gateway PC Laptops
Toshiba Qosmio f20 not booting up
Dear Sir,
Try this, remove the power plug and battery, wait for five minutes and plug the computer to power with out the battery and try to start it.
Dec 31, 2009 | Toshiba Qosmio G15 Notebook
My laptop wont start its a toshiba g15
have you tried pulling each stick of ram individually?
if there is still no boot then its safe to say that the motherboard or one of the two video cards has failed. its a pretty common on the qosmio g series
Nov 03, 2009 | Toshiba G15-AV501 Qosmio Notebook
Spilled iced tea on toshiba satellite A55-S1064 keyboard
Sorry for the inconvinience caused to you.
1. When it happens 1st immediatly u have to remove the battery and AC/DC power.
2. If you have blower then blow the air through it untli the tea particles fly away.
3. Wipe it with a soft cloth. Check wether keys are sticky or functioning well after cleaning.
4. If it is same problem then you have to remove the keypad and clean the board. To do this you need to open the laptop.
5. Else you have to replace the keyboard section.
If the problem was not resolved. Its better to consult a technical person.
Thanks & regards
Nanda Kishore.
Jun 09, 2009 | PC Laptops
Toshiba Satellite: Keyboard quits working after a while
How about replacing the keyboard? Perhaps, something was spilled on the keyboard in the past.
May 07, 2009 | Toshiba Satellite M45-S265 Notebook
Spilled water on my toshiba satellite notebook
try : start-control panel -mouse and keyboard, if nothing weird appear,try to reinstall the driver for the keyboard,you'll find it here:
If it doesn't work you will have to change the keyboard and hopfully, there is nothing wrong with the motherboard
Jan 01, 2009 | Joy Toshiba M105 S3002 Notebook
Spilled Water on Toshiba Qosmio G25-AV513
If you are pretty good at computers then you can open up the computer and see just how bad the damage is. You may need to replace the keyboard, or a few parts of he mother board. If it was water I think you would have more of a chance, but the sugar will definitely cause problems if it hit any circuit boards. Your best bet is to take out your hard drive, make it an external hard drive and get a new computer.
Dec 26, 2008 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio G15-AV501 red lines in lcd hi i have a problem toshiba qosmio power on password.its model number(pqf10a-015008).how to solved the password removed.
pop the keyboard and look on the board next to the clock battery. You should see three jumper points, WITH THE POWER OUT AND ALL BATTERIES DISCONNECTED, short terminals 1 and 2 with the end of a flat bladed screwdriver. Replace all power sources and reconnect the power.
Nov 29, 2008 | PC Laptops
Acer laptop
Pop the enter key off (be gentle), then take a Q-tip with alcohol (rubbing not drinking) and clean the connector and the rubber riser. If the problem persists, the you will have to replace the keyboard.
Jun 30, 2008 | Acer Aspire 5610-4648 Notebook
Nvidia Gfofce FX
I had the same problem, what you need to do is call Pamela Saunders at Toshiba Corporate in Irving, CA and she will get it repaired for you at no cost to you regardless of warranty. This is a bad batch of computers.
The Phone Number is: 800-457-7777 or 949-462-6000
Nov 04, 2007 | Toshiba G15-AV501 Qosmio Notebook
Toshiba Qosmio G15 Notebook Logo
530 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
