Ok I give up.
no problem stated at all like LCD cracked?
ok 2709 is only a screen , i had to google that just to know that.
so my guess your questions is how to dismantle THIS monitor
so what be first, RTM
we read the manual first, but dell its missing
they are afraid you will get hurt i guess.
the manual was leaked to here.
dell.com has user manual but not service, there.
but here it is. see page 35 , begin take down, you question is wrong, the question is what comes off first. before bezel.
https://www.manualslib.com/manual/910263/Dell-2707wfp.html?page=38#manual
btw 1st google hit.
I can advise the user manual for different Dell models, you can choose the option you need and familiarize yourself with all the characteristics .. http://dell.manymanuals.com
Let's remove the keyboard. Insert a flat head screwdriver between the keyboard bezel and laptop case and carefully lift up the bezel. Remove the bezel.
You'll find two screws securing the keyboard. Remove both screws.
Now carefully lift up the keyboard. You'll see the default memory module under the keyboard, right above the touch pad buttons. It's possible to replace the memory module without disconnecting the keyboard.
Disconnect the keyboard . Simply grab the blue tag attached to the keyboard connector and pull it up. Now you can remove the keyboard.
So now with removed keyboard you can clean it .
