SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
SOURCE: are the 1988 Johnson vro oil injection system dependable?
the older ones are dependable but they all exspecly being that old its better to be safe than sorry its if it were mine i would mix the gas thats what i tell all my coust the 90 thr 1999 omc vro were terrible the fill the carbs full of oil so i would just mix it that way u know its right just use good oil and that engine will last a very long time good luck
SOURCE: 11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
SOURCE: I have a 1988 Ford
Hello glennsteer: My name is Roger and I will help with your question. There are several explinations for this to happen. First you did not say how well the engine is running. I will guess not very well. First thing to do is unplug the fuel pressure regulator. This will be located on the fuel rail. It usually is crome and has a vacuum hose attached. Do this with the engine off,remove the vacuum hose and turn on the key.Check for any fuel coming from regulator. Should there be any leak replace the regulator. If the regulator is ok than look further. You will need a fuel pressure test gage. Place the gauge on the fuel rail test port. Turn the key on engine off. Fuel pressure should be 35-45 psi. and hold. If the pressure drops off quickly you most likely have a bad injector. THe injector will stick open and cause the plug to foul out. Most of the time if you remove the plugs you will find the wet plug. This would be the place to start. I would also check the compression on the wet cylinder.Any cylinder with less than 100 psi. will not fire the cylinder.
Any of the above problems will cause fuel to reach the oil pan as a misfire in a cylinder will wash down the cylinder wall. This will allow fuel to pass by the rings. When you find the problem and fix it change the oil and filter. Gas in the oil is not good on the engine bearings and could possibaly cause a fire. There is always more things to look at but these are the most likely.
Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
