Question about Standard (CRT) Televisions
Nopicture My tv has sound but no picture, just a white line ( horizontally) in middle of screen Having the same problem. Good sound, just a white horizontal line thru middle of screen. Sharp 25A-S100. Purchased 1993.
  • 45 Answers
Re: Nopicture
No vertical deflection. Vertical output IC, caps.
Posted on Nov 25, 2007
0 characters
3 Points
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
A thin white line horizontally in middle of screen At first could wiggle the cable conection on back of tv and it would go back to full screen now it won't
it sounds like you have horizontal colapse a very complect repair try hitting the tv if the screen comes up full picture then its a dry joint if not there is an ic or power fault toss it
Jun 18, 2010 | Sanyo DS25390 TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Standard (CRT) Televisions
Tv trouble
MOST BE A VERTICAL PROBLEM if the line cross the screen from left to rigth,,, and if the line cross the screen from top to buttom then is an horizontal circuit problem any way you need a tech how ever if you know about tv repair and have somes skill in the campus try resoldering the vertical output IC....good luck and rate me
Jan 20, 2008 | Emerson EWF2703 27" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Standard (CRT) Televisions Logo
849 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
