SOURCE: driver door panel removal and re-connect door pull
You most likley have a damaged inside door handle. To remove the door panel, you must first remove the handle bezel. The trim piece around the handle. It is held in place by 4 retainer tabs, take a small flat screw driver, insert it between the bezel and handle. Gently pry away from the handle. If you look in the crack around the handle you will see the tabs. When you get that off, remove the switch assembly by prying up on it gently, unplug the wiring. There are 2 screws in the door panel where you pull the door shut, remove those also. Start at the bottom front of the door panel, pull outward firmly, but not violent. The retainers will come out, you will most likley break some, this is common. The inside handle is about $45 from your dealer. If it is the handle it is held in with 1 rivit, drill it out with a 3/16 drill. Replace the handle, reassemble. Good Luck.
SOURCE: How do I remove the front interior door panel polo 1400 1999
You'll need a torx bit for the bottom screws. The door handle comes apart (using a screw driver) to expose 2 phillips screws holding the door handle to the door, after you get those out, pop the rest of the push clips out by firmly pulling on the door panel near the bottom, There may also be another screw on the TOP Front (near the mirror) very small phillips. Once you have the door panel loose, lift UP on the door panel to remove. Once you get that panel off, you'll have to remove all the other screws to get the window regulator out (lots of 10mm bolts). Unclip / unconnect the connections etc..
SOURCE: how do I remove interior front door panel
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. then just remove the bolts for the mirror
SOURCE: Are white front door dishwasher replacement panels available?
Absolutly! There is a website that allows you to do a bunch of stuff to the front of your dishwasher , including changing colors, without actually unscrewing anything. Check out www.applianceart.com. They do sell stainless metal panels for cheap there too.
SOURCE: Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
call for service to change the outer panel.it takes about 15min.
