How do I switch from sky Tv to normal TV?
When I switch on the tv it shows skyware on the screen.
    Top Expert:
  • Televison & ... Master
  • 58,650 Answers
Try a different input to your set
Posted on Aug 18, 2018
  • siamisang sebogo
    siamisang sebogo Aug 19, 2018
    Thank you Ray, but even when I press the input button it doesnt change.
  • ray gallant Aug 19, 2018
    then you need to see a local repair service
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
Chris.
Posted on Jan 31, 2008
  • 1779 Answers
SOURCE: CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Posted on Apr 04, 2008
SOURCE: gu15wdvdt tv .sky remote code
posted by mike 13 aug 2008
I have just had sky installed and the code for grundig gu15wdvdt is 1239
Posted on Aug 12, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
I have sky tv and a marantz system, marantz system flashes pcm dig and tv loose signal intermittently, help
Your Sky box might need a firmware refresh. Switch it off at the mains socket. Press and hold down the BACKUP key on the SKY BOX (not the remote). Switch on at the mains and keep the backup key pressed down until the TV shows an info screen that the box is updating.
Allow the box to complete the cycle.
Try your system again.
Sep 02, 2014 | Marantz Audio Players & Recorders
How do i switch from wide screen to normal screen on my Bush btv663dvdsil using my sky remote which is coded for my tv
Hi there
On your remote there should be a "adjustment" button, push that
and on the screen appears a picture of the different ways you can adjust your screen and choose accordingly..
good luckkolbrun
Jun 10, 2012 | Televison & Video
WHEN TV TURN OFF SCREEN LIGHT SHOWS SKY CLOUDS BACK GROUND COLOR WHY
Hi, Your tv is start to spoiled. But it is quite normal if your tv is back to normal after about 5 minutes. If after 5 minutes the screen stranger background still persist, unplug your power chord. This will totally cut the power supply for your tv.
Jan 20, 2011 | Hitachi 60V500 60" Rear Projection...
Need an activation code for my sky+ remote to operate the volume on my samsung lcd tv le40s8.
switch to sky on tv and press interactive on sky remote then move down to sky customer service (select) once screen has loaded move down to programe your remote you will need model number and make of tv press select and then enter the make of tv by moving down list once found select and repeat for model then follow on screen instructions
Dec 11, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
Feb 13, 2008 | Televison & Video
Hi.
then system setup
Chris..
Jan 19, 2008 | Televison & Video
Televison & Video Logo
624 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
