SOURCE: The scooter rar wheels locked up nothing moves
hi, if the freewheel lever is jammed which is located on the drive motor, take the rear cover off and make sure the lever is not bent,
you will see how the freewheel lever is mounted under normally a rubber cover on the side of the electric motor ,
Let me know
SOURCE: gears do not engage.\r\nis in freewheeling mode
If you remove the wheel can you spin the gear cluster forward with no resistance? Does it ratchet when spun backward? If yes and no, the hub is shot.
SOURCE: blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
SOURCE: I bought used mprv 4
take the freewheel levers and move them up and down a few times then leave them both in the up position. Turn on the chair and see if it works correctly The noise you hear are the motors or motor running because one or both levers are in freewheel.The clicking you hear is the electric brakes engaging when you move the joystick Hope this helps
SOURCE: freewheel lever broken
For the wire to come all the way out lever on top of the trans must be broken. I've seen a few. Jack rear of mower up, remove rear right wheel and find remnants of lever. With pliers turn this all the way forward, mower will now go. But to fit new lever trans will have to be removed. Dont forget the axle key.
