Question about Electrolux Kitchen Ranges
Electrolux EKM4300 flashing
My kitchen assistant, EKM4300 bought 2016, starts flashing when I attach the cord, even if I have selected OFF. I can't get it to stop, I have read the manual trouble shooting, I have tried a lot of things. Any Ideas about what to do?
SOURCE:
SOURCE: denon AVR 1905
Hello. Tonight I got the same problem with my AVR-2802, after listening to Sheryl Crow, and Too Slim and the Taildraggers at very high volume for an hour or so. Nasty smell and really hot transformer at shutdown. I removed the cover and checked for visible damage, found none. Checked the power transformer with an O-scope, and am getting only 1 to 2 V peak from all the secondaries, with the full 177V peak on the primary, with secondary plugs either all connected or disconnected. Also with secondaries all disconnected, I get the same symptoms of no display, standby power lamp only. No bad fuses. I suspect the power transformer has gone out, am searching for a service manual. The power transformer is about $120 US.
Posted on Jan 05, 2008
  • 7 Answers
SOURCE: Dishwasher stops inbetween rinse and dry
hi
if the problem faults within the first 1 minute the first check the connections on the main module behind the control panel,as you you look at the control panel there is a pink connection to the left,if this looks like it has got hot then theres yopur problem(you will find that the joint on the board has come loose from the soldered joint,module requires replacing.
if this connection looks ok then the heater is open curcuit and will require replacing.
Posted on May 18, 2008
SOURCE: Vicking VIDV500 Kitchen Hood
I have a 36" V600 wall mount hood. Replaced both bulbs and they still won't light. Fan works perfectly. Unit has on and off switch and dimmer switch. Any suggestions?
Thak you, Mike
Posted on Dec 01, 2008
  • 901 Answers
SOURCE: my Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
Posted on May 28, 2010
SOURCE: I have an Electrolux Dishlex
hi peter, according to manual book -10 is not filling water fast enough. check inlet hose and valve, check pressure switch and pressure SW hose and clean sump filter which located bottom of tub that plastic strainer and stainless mesh clean them spotless. sometimes caused by this filter block the water passage and change pressure sw's leadings. and clean sump as well. b4 suspect PCB this filter cause many problem like not heating water, doesn't keep water. if dirty filter is the one you will save at least $300- for service man to come out and change the PCB for nothing. I think clean the filter doesn't hurt anyone.
Service Man K
Posted on Oct 16, 2010
How to install the oven door?
Hello Barbara, thank you for your inquiry!
I see that you need assistance with installing the oven door on your Electrolux range. I have located the use and care guide for the model, CPCS389DC2. I have attached a copy of the guide for you to review and on page 17 it will provide you with instructions on how to replace the oven door. Hopefully this information is helpful to you. -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318203863en.pdf
Jan 15, 2016 | Electrolux Kitchen Ranges
Need a wiring diagram for Electrolux range model EW30EF65G5H
Hey friend, thanks for your inquiry!
I have located the wiring diagram for your Electrolux range, EW30EF65GSH. The link will be attached. I hope this information provides you efficient assistance. -Matt
Frigidaire Manual Search Results
Oct 07, 2014 | Electrolux Kitchen Ranges
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
I have a Electrolux EWF 1481. The start/pause is flashing and the machine don't start
Good Morning JeanPierre, thank you for allowing me to assist you!
Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the washer on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potentialwiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Sep 29, 2013 | Electrolux EW1000i Front Load Washer
I have anElectrolux EDC47130W sensor dry 7kg condenser dryer. Its only a week old and worked great till yesterday. Whenever i select a program or time setting the start/pause button starts beeping and...
I think that there are errors on the program controller . As your set is new I would suggest that no tampering be done but the matter reported to the Electrolux dealer from where you had bought the machine for th privilege service under warranty.
Sometimes it might be better to register the service as the warranty gets void if tampered.
Mar 30, 2011 | Electrolux Kitchen Ranges
Electrolux el6985 cord brake does not hold how do
you have to replace the cord winder. Since eureka bought out electrolux their product quality has really went down the drain.
Jan 02, 2010 | Electrolux Harmony Canister Vacuum -...
CHANGING DRYER CORD
All you need to do is, attach the middle connection from the cord to the middle post on the dryer. The 2 outside connections on the cord will attach to the outside posts on the dryer. It does not matter on the outside connectors as far as which side they go.
Make sure they are fastened down tight. If the connections are loose at all, they will go bad.
Please let me know if this has helped you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | Frigidaire GLEQ2152ES Electric Dryer
How to replace sheath cord on eletroux
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=840565
Generic problem for all Vacuums
Posted by ellie_pesca on Jul 27, 2008
How to replace sheath cord on Electrolux
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Just bring in a sample of the Electrolux sheath cord to your local vacuum cleaner dealer in your area and chances are he will have the part to replace the sheath cord for the Electrolux. Or you can contact the Electrolux factory website or the cust serv line and supply them with the brand name and model # of the vacuum and they can either send it out to you or let you know where you can get one. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 27, 2008 | Vacuums
Power cord plug broke and cord went back inside.......how do i open??
Call your local Electrolux office. Trying to fix it yourself will void your warranty. If you need any assistance call 570-326-1731 and ask for Liz, I will be happy to assist you if I can.
Nov 19, 2007 | Electrolux Guardian Bagged Canister Vacuum
Kitchen Ranges Logo
71 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
