Question about Microsoft Xbox 360 Console
Wireless connection of xbox 360
Everything setup wpa key in and is connecting but IP address keeps failing we have put in the same ip address as our son uses for his xbox live as we are connected to the same netgear router but we are wireless we now need to get an ip address for our xbox 360 but don't know how or where to get one please advise us. thank you
    Problem Solver:
  • 18 Answers
Re: wireless connection of xbox 360
You can find your I.P adress on the PC you use at home that is connected to the wireless modem.
if not theres an option on the xbox 360 to find the I.P automaticly try that!
hope this helps please rate me
Regards Grant
Posted on Nov 27, 2007
I think the problem is (for comcast users) the device given by comcast as arris touch-tone-device. Eventhough connected to a router this device doesnt allow to share the IP betwen the PC and the Xbox..........
that's very sneaky and tricky for comcast...and i also i find it unhonest...........
other internet services as at@t make easy to connect to xbox live by using share isp....gateways and routers
0 characters
3 Points
Ip address fails test connection
you need to set your 360's network to automatically detect your settings if you have other devices hooked up to the airport and they work it is not the Airport.
When it says IP address failed it has nothing to do with comcast it is your LAN having issues not your WAN
Mar 30, 2009 | Microsoft Xbox 360 Wireless Controller
Xbox 360 Connection to internet
the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
Jan 03, 2009 | Microsoft Xbox 360 Console
Cant get xbox live connected
You have to make sure that your xbox knows your ip address and if your using wireless, your wep key. Your wep key should be on the back of your wireless router and you can make your xbox recieve your ip address automatically by editing the settings. you can edit settings by testing your connection. If your xbox does does not have your ip address, next to ip address it will say failed and next to that it says edit settings.
Nov 28, 2008 | Microsoft Xbox 360 Console
Ip address
do u have the internet if so connect the ithernet cable to the modem and try again
Oct 21, 2008 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Xbox 360 to Linksys wireless modem...
OK I think the easiest way to connect the xbox to the linksys, is if you configure your XBOX to have a static IP address, because the xbox will not have to pick an IP address every time you connect to the internet using the Linksys router and will not have conflicts with other PCs on your house, if you have any. What the linksys does is to convert your Public IP addres into a Private IP address, so example if your ISP gave you an IP address of: that is your IP address for you, then the Linksys converts that number (NAT) into a private IP address so it can be share with many computer inside your house using a single Public IP address. The Linksys always transform it into 192.168.1.?=any number between 1-256 thats the defaults IP address from the manufacturer but you can change it if you want. Ok enough info about NAT or IP jeje.
Where going to use the default IP addres for an easier setup.
First: On your XBOX 360 dashboard go to SYSTEM, then Network Settings, then Edit Settings, then choose the option manual, here put the IP address= (if 33 doesn't work use another numer like 20 or 45 just pick a number between 2 and 250) ; Subnet Mask = ; Gateway =; DNS options put Automatic. And see if it connects. If it doesn't work just post it here, any problem that you have.
Aug 22, 2008 | Microsoft Xbox 360 Console
Ip address for xbox live
ok, firstly i hate these problems.
first things first, switch your hub off (leave for 2 mins) switch back on, this may refresh the ip address, also switch your xbox off.. then try agian.
Get back to me and let me know what happens from here.
oh also are you connecting your xbox to the pc? or directly to your broadband hub? if you can connect it directly to your hub, this should solve any problems
Aug 07, 2008 | Microsoft Xbox 360 Elite Console
IP Address keeps failing on my Xbox 360
You shouldnt have an amp, when you do this. Also, you arent supposed to plug the modem directly into the console. It is supposed to be plugged into a router, which is pluged into a computer. That was, you can configure it.
Apr 04, 2008 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
156 people viewed this question
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
