Question about Baby & Toddler Car Seats
Yamaha vino scooter underseat storage
All I need to know is how to open the seat on a yahama vino seat to get to the storage area underneath
Re: yamaha vino scooter underseat storage
Remove fuel cap take out 2 cross tip screws remove panel then you can get to the lock mechinism
Posted on Mar 18, 2009
Re: yamaha vino scooter underseat storage - Baby & Toddler Car Seats
Sorry to report that does not work.
Posted on Jan 13, 2008
You turn the key to the left and it releases the lock.
Posted on Dec 01, 2007
0 characters
3 Points
How do you remove the cover and belts on an evenflo car seat with this number on the side 25801158?
Turn the booster seat around to the back and locate the metal splitter plate that the harness is attached to. Remove both harness straps from the splitter plate. Locate the TensionRight knob located on each side of the seat in the front by the baby’s foot area. Turn the TensionRight knob to the back as far as it will go to take up the slack on the splitter plate strap. Pull both harness straps through the seat back to the front of the seat. Remove the harness strap from both sides of the chest clip and from the buckle tongues. NOTE: Please leave the buckle tongues locked into the **** strap for storage. Remove the harness strap from the seat. NOTE: Reattach the chest clip to the harness strap so they don’t get lost. Turn the booster seat upside down and locate the metal harness anchor. Turn the metal anchor sideways and push it through the slot to the front of the seat.
Sep 08, 2010 | Evenflo Generations
I cannot find my primo viaggio installation instructions for the car seat and I need to switch the base from one car to another and the other car has a back latch so I know it's slightly different...
nicole...if you cannot locate the car seat and this is a suggestion for others that have car seats.... even if you have the instructions... stop at the local police station, fire dept or health unit in your area. they are more then happy to help you make sure the car seat is installed properly. i know in my country (canada) that they have four or five baby seat "cliinics" to assist in making sure that car seats are properly installed.
Please take a moment to rate this solution thanks
Jan 24, 2009 | Peg Perego Primo Viaggio
How do u take off the cover for the seat?
With a small amount of force those little seat belt clips will just pop in and out. I sometimes use a butter knife to pop them out. It is always quite stiff the first time.good luck p.s you made perfect sense.
Dec 21, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
I need to know how to take the liner out of the baby car seat so I can wash it.
You have to unlatch the shoulder straps from underneath then unscrew the side handle to remove the elastic. Then your able to completely remove the cover. Just pay attention, because getting if off is the easy part, putting it back can proove difficult. Good Luck!
Jul 27, 2008 | Graco SnugRide - Giselle Infant Car Seat
Ariston microgenus 27 pressure on 0
Filling loop is underneath the boiler, easily identified as a chrome coloured braided pipe with a black tap at either end. Open right hand tap first then left hand one . Fill system till presure gauge reads just over 1 bar when system is cold. Then turn both taps off.
Jul 08, 2008 | Combi Centre DX - Mango
LATCH belt storage in rear position
 it definitely is NOT self explanitory as to where the LATCH is supposed to be anchored when not in use. It took some time, but I figured it out. The Top Tether should be hooked on the recline prop/foot/base area - depending on which way you have this positioned - for forward or rear-facing use, the piece to hook the top tether on could either be towards the front (rf mode) or back (ff mode). It's just a simple cut out in the plastic. The Lower Anhcors need to be clipped to a small plastic notch along the back side of the seat shell - you have to lift up the cover to get a good look at them - they are towards the top of the seat on the back and don't really look like much but do secure the lower anchors when attached.
I hope that helps! Please let us know if there is anything else we can assist you with.
Jun 21, 2008 | Maxi-Cosi Priori
Need to remove the back passenger seat from a 2003 Santa Fe for cleaning
you need to unbolt it from the floor - underneath in two rails are four bolts or nuts.
Dec 17, 2007 | Baby & Toddler Car Seats
Adjusting chest clip?
The belts usually adjust underneath the seat, have a look there.........
Aug 16, 2007 | Evenflo Express
Baby & Toddler Car Seats Logo
1,033 people viewed this question
Top Baby & Toddler Car Seats Experts
Level 1 Expert
Jennifer Rock
Jennifer Rock
Are you a Baby and Toddler Car Seat Expert? Answer questions, earn points and help others
