Question about Sony KDF-E55A20 55 in. LCD Television
Lamp light flashes red
I went to turn on my tv this morning and the green light flashes a numerous amount of times then the lamp light comes on and both lights flash red.
  • KAPZILLA Nov 26, 2007
    I turned on the T.V. and it was dim. Then the T.V. screen went blank and the lamp indicator light started flashing red.
    Sergeant:
    Champion:
  • 231 Answers
If lamp LED is blinking then replace lamp ..
Posted on Nov 30, 2007
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV will not power on, green light flashes 6 times
Either you have a defective Lamp or your Ballast Board has went out It is what turns on Lamp CK out Encompass Parts Distr online type in your Model number then it should list all the Parts for your TV or Call them 1-800-638-3328 also make sure Fan to Lamp is working if it stops running Lamp will not light.
Dec 01, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
TV will not turn on.
If it is Sony KDF-E55A20 TV then replace its lamp as symptoms shows lamp is broken/ dead.
lamp replacement procedure is written in user manual and let me know if you have nay further question.
Thanks.
Sep 27, 2009 | Sony KDF-E55A20 55 in. LCD Television
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Sony KDF-E55A20 55 in. LCD Television Logo
485 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
