I have cable. working with a d-link router. Tried doing manual resets, tried resetting modem and then router. PC can see router. Router seems to be getting an IP address and the internet works when i plug the modem directly into the PC. I think it's definitely a router issue.I have cable. working with a d-link router.
Do you have cable or DSL? This is important to know.
You can try doing a manual reset, it should fix the issue right away. Locate the button around where the Ethernet ports are in the back, while the router is on, push that button gently with a ballpoint pen or something that will fit, hold it in for 30 seconds and let go.
The reason why if it's cable or DSL is important, is because with Cable you may need to clone your MAC address, and with DSL you most likely don't have to.
I also have another question, does your modem support PPPoE? If it does, you might need to set it to bridge mode for the router to work, and the router will then do the authentication for you.
Please try those things and let me know.Do you have cable or DSL? This is important to know.
You can't post conmments that contain an email address.
Please connect your computer directly to your DSL / Cable modem and check if your internet is working fine, if not turn off your modem and restart after a minute or two.
Now check again if the internet is working by directly connecting your laptop to your modem. if it is not working, contact ISP. if it is working, turn on your router and check if your wireless connection is working.
If you wireless connection is still not working, please check if you have plugged the modem to the internet / WAN port behind your router.
Also try logging to your router page (refer to manual for procedure) and try changing the wireless channel.
If you connect the computer to the modem , does it works ? If it works then modem is working. now connect the computer and modem to the router. open the set up page of the router. change the Internet settings according to the ISP. Click Here for more information about router and networks.
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem. Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet. Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
This sounds like a problem with your DSL modem, not the router. Try unplugging both devices and wait about 10 seconds. Plug in the modem first and wait about 30 seconds (at this point the Internet light should be on). Now plug in the router and wait another 30 seconds. This problem is normally due to the modem not getting sync. I would try plugging your laptop directly into modem if this doesn't work to see if you then have Internet. If not call your ISP.
When everything is connected, the "WAN" light on your router should go on, as well as the lights for whatever network connections your are using for your computer.
Obviously the cable that you used to connect your computer directly to the modem is working, so try replacing the other one.
Try turning everything off, PC, Router, and Modem. Then turn on the modem, then the router, then the pc. Your modem needn to connect, then the router will be assigned an ip address, then your pc will acquire an ip from the router.
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
