Amana Laundry Super Capacity Plus  Elustra Stainless Steel Tub Washer - NAV8805EWW
Problem for Amana Laundry Super Capacity Plus (3.3 Cu. Ft.) Elustra...
Leaking from bottom
By tleah27 on Aug 03, 2009
leaking from bottom as soon as washer fills
Solution #1
posted on Aug 03, 2009
Not Rated)
Online-Tech
Rank: Wiz
Rating: 85%, 21 votes
I would request you to pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Thank You for contacting Fixya.com
Was this helpful?
Yes
No
Popular Solutions for Amana Laundry Super Capacity
Questions and Unsolved Problems for Amana Laundry Super Capacity
Do you recommend Amana Laundry Super Capacity Plus (3.3 Cu. Ft.) Elustra Stainless Steel Tub Washer - NAV8805EWW?
Answer
Answer
What would cause the hose that connects to the bottom of drum for water removal to become... (More)
Answer
My Amana Super Capacity Plus Washing machine is 9 or so years old. It has recently begun leaking... (More)
Answer
how do you change a belt on my amana washer.it looks like i take off the 4 large springs and... (More)
Answer
The washer on the rinse cycle sticks and the water just runs out.
Answer
Amana wahser model #LWA60AW stops working mid-cycle. I turn it off and let sit 5 or 10 minutes, then... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
