Question about Whirlpool Dryers
How do i reset the whirlpool dryer showing F!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 30 Answers
Depending on the year, the f1 code may be a control board failure code. Board can be replaced or in my case a 15 or so minute fix by soldering one of the blown out solder joints on the board. If you decide to check the board yourself, unplug the unit before disassembling. If it is the solder joint it will be very evident which one has fried once you take the board out.
Posted on May 02, 2019
SOURCE:
Have a whirlpool cabrio dryer model number WED8500DW1 the screen just flashed very fast like the touch screen is broken is there a way to reset the dryer
You can download the manual for your dryer at the website below. It's 40 pages. It may contain reset instructions, I don't know.
Whirlpool WED8500DW Manual
Nov 17, 2016 | Whirlpool Dryers
How do I reset my whirlpool Cambria dryer showing a c6 error code
Unplug it. wait 45 minutes then plug it back up. It should clear all codes.
Nov 07, 2016 | Whirlpool Dryers
98 series. Why doesn't it run?
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
https://www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry
This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool Dryer and it does notstart up. ... the button won't start it, and putting those wires together doesn't start the dryer, what ...
What to Test When Whirlpool or Kenmore Dryer Won't Start ...
? 7:17
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jan 24, 2013 - Uploaded by canyonman1963
What to Test When Whirlpool or Kenmore Dryer Won't Start orRun ... discusses all of the common causes of an electric dryernot starting or running. Category. People & Blogs. License. Standard YouTube License. Show more
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...
? 7:29
https://www.youtube.com/watch?v=SPRqKVE8JfY
Oct 21, 2011 - Uploaded by canyonman1963
This video is the 2nd of several that will show you how to diagnose and repair a Whirlpool or Kenmore electric dryer that will not start or run.
Jan 13, 2016 | Kenmore Dryers
Is there a way to reset the dryer?
Need exact model number will let you know what code means
Mar 22, 2014 | Whirlpool Dryers
I have a whirlpool azb 9750 and seems to have no pore but the fuse in the plug an the socket power is all ok, is there an internal fuse or thermal reset within the dryer
There are some overload/temperature switches within the dryer. Most reset when the overload/temp gone. You could open up the back and follow the wires to the overload switches and check with an electrical tester to see if you have power passing through each. The wiring diagram should be inside the dryer, and show each switch.
Jan 26, 2014 | Whirlpool Dryers
What does the code F2 mean in the time window of the Whirlpool Cabrio gas dryer and how do I reset the machine?
Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes
  • PF--Power failure
  • AF--Restricted air flow
  • F01--Primary control failure
  • F02--Keypad/User Interface failure
  • F22--Exhaust thermistor open
  • F23--Exhaust thermistor shorted
  • F24--Inlet thermistor open
  • F25--Inlet thermistor shorted
  • F26--Motor drive system failure
  • F28--Moisture sensor open
  • F29--Moisture sensor shorted
  • F30--Restricted air flow
looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
Sep 07, 2012 | Whirlpool Dryers
Dryer will not turn on. Status bar not lit. Three beeps when on button is pushed.
This video shows how to change a thermister in your dryer. Right next to it is the none resetable fuse. Check for lint blockage in the vent and then replace this fuse. dd08c68.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 09, 2010 | Whirlpool GGW9250PL Gas Dryer
Run no heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 13, 2010 | Whirlpool Dryers
No heat in dryer and can't find reset button
Probably is no reset button on/in the dryer. Go here for more info on no heat in the dryer: Dryer Repair Help
www.RepairClinic.com
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool duet dryer - PF error
Here are 2 good ones from very large inventory companies
http://www.apdepot.com/index.asp
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 24, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
87 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
