SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
SOURCE: Calcium build up in my Arctic Spa Hot Tub
The worst calcium build-up I have seen on an Acrylic shell was actually caused by incorrect use of chemicals by the owner. The owner was dosing in very large quantities which was the cause of their issues. Little and often is the best way to go when adding any chemicals to a hot tub.
I don't rate Aqua Finesse at all. I have seen cirulation lines partially blocked due to similar products, I wont recommend it to any of my customers or use it myself.
If you were my customer, I'd be running through your chemical routine and the quantities that you add at any one time. It's possible that you are over-dosing and causing the problem to get worse.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
SOURCE: SPA PUMP REPLACEMENT
There are only two ways you can avoid a Sunami. You either have to clamp the hoses or drain the Spa. I found out the hard way that I need to drain the Spa when changing the pump. The service guy, using the hose clamps, messed up my Jacuzzi room big time. The clamps just won't do it.
