Question about Hotpoint FFA90 Bottom Freezer Refrigerator
Pop full of ice
The pop is full of ice its on 2 but it still freezing all the food then some time it dosent.its a hotpoint ffa90 future
  • 833 Answers
Sandy, this sounds like a bad thermostat. First: does the unit seem to run continuously? Try this: turn the stat to a position near 'off'. Does the compressor turn off? If not: change the stat. Before you do: check the position of the thermostat bulb. On some units, you can see a thick silvery 'wire' coming out of the thermostat housing. It should be fairly straight and generally located near an air duct inside the unit. If it has become dislodged, put it back. If it is broken or kinked, it needs to be changed. Be sure to unplug your fridge before working on this!
Other possible problems: You may have either low gas or a bad defrost timer. Low gas generally will show up as frost on one side of your freezer compartment and airflow will be fairly low when the fan is running. The defrost timer, used to schedule a defrost cycle is generally not a big problem on GE/Hotpoints, though.
Posted on Nov 25, 2007
On my Hotpoint FFA90 fridge freezer occasional leaks occur at the bottom of the freezer where ice accumulates. The fridge section above is fine. Any suggestions?
There is one in the freezer section as well. It's a small white tube. I've had the same thing happen with mine. I just took everything out of the freezer, and used hot water. It's caused by condensation buildup in the drain tube, which then freezes, obviously because it is a freezer after all. Hot water usually does the trick. Just be sure to clean it up, and dry it off really well so it doesn't re-freeze and cause the same issue.
Aug 26, 2016 | Hotpoint FFA90 Bottom Freezer Refrigerator
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Ffa90 ice at bottom of fteezer. How to locate drain.
Don't think there is a drain on the freezer. Remove the food from the freezer defrost I would also check the seal to ensure that no moister in getting past the seal forming ice at the bottom.
Apr 09, 2012 | Hotpoint Freezers
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Freezer defrosting by itself
what's the model number off of the fridge?
Feb 07, 2018 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
Jan 25, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint rfa18 Fridge Freezer
Is the back wall full of frost? If so you have a defrost problem, most likely the defrost is stuck in the run mode. this is located above the controls area in the fridge.
Nov 14, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Future ffa90 fridge freezer
yes first are you in usa second get your correct serial number off the serial plate then go here
Feb 18, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
137 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
