Question about Philips Combination Televisions
Posistor 91 for Philips TV/VCR combo
Can you tell me where to purchase a degauss resistor for a Philips 20PV220/07 TV/VCR combo please, I believe the part No is 232266296708 and the can is marked S+M T209 0003 I also believe it to be known as a posistor 91. Many thanks, Russ.
SOURCE: TV code for Emerson EWC 1301 TV/VCR Combo
how do use revmote to program tv vhs thank you11
Posted on Jun 21, 2008
yp *****
Posted on Jul 19, 2008
SOURCE: Orion tv/vcr combo to work with Philips universal remote?
phillips universal remote with orion 1326 tv.
ned code
Posted on Feb 17, 2009
SOURCE: daewoo tv/vcr combo ccodes
Hi here are some codes I have 0278 0624 If they dont work try programing the VCR
first then the TV. To program the VCR put a tape in and put it on play after you put
the code in hit the power button the vcr should stop playing. If that works then program the TV.
Some TV/VCR combo's require two codes. Good Luck
Posted on Feb 19, 2009
  • 11896 Answers
SOURCE: need universal code for philips sru3004 universal remote
here are some sites with your code.
Posted on Apr 15, 2009
  • 35 Answers
SOURCE: I need a remote code that will work on the Comcast
try the philips combo codes 20035, 20081, 20618, Dale
Posted on Jul 07, 2009
0 characters
1 Points
Need a remote control code for philips tv vcr combo ccc090at as a result of the Comcast dta conversion from analog to digital. I have tried the combo codes 20035, 20081, and 200618. Plus I have tried...
That unit may have been built by Funai, the poorest of the Japanese electronics companies.
You might try any codes you find for the brands listed below, all of which are made by Funai:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
Oct 25, 2009 | Philips CCC090AT 9 in. TV/VCR Combo
Older Quasar Video TV combo Model UU1220AW, SN VSOS1226
can you please send me the tv vcr combo code for my philips remote, to the old quasar tv. thank you
Apr 20, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
I need to degauss this TV.
This type of CRTs can only be degauss using a degauss coil not through the TV menu.
Apr 14, 2008 | Philips Magnavox 20MC4304 20 in....
Color messed up on tv since lightning strike
your tv may have ben magnetized by the lightning strike.
tv's have an automatic degaussing circuit that demagnetizes
the pix tube when the set is turned on. this degaussing circuit
may not be working or magnetism may have been too strong for
the internal degaussing to correct.
contact local tv repair shop in your area see if they can manually
degauss your set , it should be a min. service charge around $25.
Mar 22, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Digilogic vcr\dvd combi
I have just pressed the on button, on the remote, kept it held in for a few minutes and beleive it or not, it has come off SAFE and works fine now.
Hope it works for you.
Jan 20, 2008 | Philips Magnavox 20MC4304 20 in....
Toshiba 24"TV VCR/DVD Combo
Hello firstly switch the tv off at the wall socket and leave overnight, If the fauld still there in the morning then the degauss thermistor inside the tv has failed and requires replacement.
Jan 16, 2008 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Combination Televisions Logo
451 people viewed this question
Top Philips Combination Televisions Experts
matt martin
matt martin
Are you a Philips Combination Television Expert? Answer questions, earn points and help others
