Https://www.davisinstruments.com/resources/weather-monitoring/#support
Look for your model number. The issue is setting the ISS to the right channel and then setting the console to find it.
SOURCE: setting radio stations
The solution for setting the radio station on a Pioneer DEH P2000, is to tune the station you want programmed and hold down the desided channel number until the program number appears on the display.
BC
SOURCE: my midalnd weather radio WR-100
The high pitch sound is a sign of the autooscillation of the intermediate frequency amplifier from the tuner in your radio - hardware defect. The only way to fix that is to replace the tuner and realign it. This would cost you about $100 for the part and labor.
Since you can buy a brand new unit for less than $40 it's clear what you should do.
SOURCE: I want to reset my Alpine 7893R headunit back to
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you remove the positive battery connector and let it sit for atleast 5mins. or more before reconnecting it. This will reset the system as well as your radio in the car.
Hope this helps and thank you for using FixYa! Have a good one!
SOURCE: We just purchased the Motorola
Reset to Factory Defaults (Pg. 34) Reset to Factory Defaults will set back all radio features to the original factory default settings. To do so, press PTT, SB2 and SB1 simultaneously while turning ON the radio until
you hear a high tone chirp.
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Programming instructions begin on page 36.
Best regards.
