Question about Jabra Radio Communications
Why does my jabra active elite 65t only have a 10 foot range . I just got them out of the box and charged them. A little disappointed
I just got the Jabra GO 6470: The desk phone doesn't ring in the headset, so if you're not within hearing distance of the desk phone (but within the 300 foot range of the base) you don't know...
what i gather from what you have said is that the headset doesn't ring at all. this would indicate to me that the headset is not paired with the base.
normally when pairing devices the base station will look for the device but at the same time you will have to hold the headset power button for at least 5 seconds for that the other device can capture the signal.
i will look into this for you but try this method if applicable but the bluetooth devices do have to be paired in order to work.
Jun 15, 2011 | Jabra GO 6470 Wireless Headset with Touch...
What kind of foot paddle ofo I use for this sewing
You can use a standard foot control, they wire in very easily
Jun 27, 2010 | Brother XR-65t Mechanical Sewing Machine
I can't get the pressor foot on the silver part came off and the actual pressor foot
Place the foot under the arm while arm is in up position. Put arm in down position and foot should snap into place (line it up where it is supposed to go together before lowering the arm).
May 11, 2010 | Brother XR-65t Mechanical Sewing Machine
My Jabra headset won't pair with my phone--my phone can't "discover" the headset. The headset is charged and when it is turned on, it blinks three times in a row
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Dec 14, 2009 | Jabra BT2050 Bluetooth Headset
Jabra BT350 not taking a charge
the battery needs replacing not really worth it
Mar 15, 2009 | Jabra BT350 Bluetooth Headset Headset
Material will not move forward
Make sure the presser foot is coming all the way down. Check your stitch length setting too.
Mar 01, 2009 | Brother XR-65t Mechanical Sewing Machine
Jabra bt2020 will not charge/function
I don't know how long you have had the headset but it sounds like it isn't holding a charge.  Contact Jabra to find out what the warranty is on the headset.
Nov 12, 2008 | Jabra BT2020 Bluetooth Headset
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
Unit won't charge and I get no lights
I have the same problem. it's due to a faulty pover-cell inside the headset. i have also read that the charger can be inserted the wrong way, this would in turn kill the battery by giving it a reverse charge.(not sure about that) as i tried this after finding the unit defective and it will only plug in one way.. the only suggestion that i can give is contact Jabra directly. iv'e read that they will replace any headset in this range for free, here is the address for their site. http://www.jabra.com/Sites/Jabra/UK-UK/pages/Contact.aspx Hope this helps.
Sep 14, 2007 | Jabra BT500 Wireless Headset
Radio Communications Logo
59 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
