SOURCE: Philips 50P8341 50 in. Rear... Problem:
you need to change the coolant in the CRTs ( picture Tubes) and the set will get its color and clarity back.
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
SOURCE: sharp aquos red flashing light tv won't get picture
if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
SOURCE: Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
