Hardware & Accessories Logo
Ann KEATS Posted on Aug 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have set my timer but it still does not go off. Is there a final step that I am missing I have programmed time of day, start water, how long program on, manual off.
Bill Boyd
Level 3:
Top Expert:
  • Master 53,816 Answers
  • Posted on Aug 13, 2018
Bill Boyd
Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11926104
Points
172802
If it is digital , did you press save
Testimonial: "Thanks Bill, This is a gardenline timer and i dont have a save button. I tried the + button but it still wont go on at set time,"
  • Bill Boyd Aug 13, 2018
    take it back and have you shown how to work it or simply get a refund
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
  • Posted on Dec 10, 2008
SOURCE: Instruction manual to program HB77R
Here is the instruction manual your looking for:
Intermatic HB77R
Hope this helps and please remember to rate this!
Anonymous
  • Posted on Jun 29, 2009
SOURCE: vigoro water timer 196 036 water timer programming
every x days vs every x hrs. (once a day or every 12 hours)
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 19, 2010
SOURCE: instruction manual missing for Woods Industries
Especially for you - click on this link and smile: http://www.ccixpress.com/cci/Marketing/Woods_Canada_Timer_Instructions/49556.pdf Pssssss - don't tell anybody else. :)) Rate me, plz.
Testimonial: "Unbelievable! thanks very much for your help...whoever you are. I had given up...when this email arrived. The manual was exactly the right one... "
Anonymous
  • Posted on May 14, 2010
SOURCE: Utilitech Self-Adjusting Wall Timer- #0192773.
Here is the url to the pdf file. You can then magnify your computer screen.
http://www.thencc.com/LS/Instruction/LW60418_Instruction.pdf
A
Anonymous
  • Posted on Oct 16, 2010
SOURCE: I have a intermatic ej351c
There might be a couple things that are easy to overlook.
Press the button to see if lights come on >>> if light do not turn on with manual override, then light might be burned out or circuit breaker tripped. Sometimes a breaker is tripped but you can't tell by looking at it
1) The timer is used on incandescent bulbs only. I don't know why, but it says no
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
2) Is the red indicator light ON?
For programs to work, timer has to be in automatic mode and the red indicator light will be ON
The Switch Timer can be used in two modes. manual & automatic
To switch between modes, quickly press the dial twice:
AUTOMATIC MODE: The Switch Timer will turn your lights ON or OFF according to programmed settings. The RED indicator light stays ON when in Automatic Mode.
MANUAL MODE: Programmed settings are inactive, and
the Switch Timer will only turn the light ON or OFF when
you push on the dial.
RED indicator light stays OFF when in Manual mode.
3) setting current time> lets look at the red indicator light while doing this
Move switch lever to OFF-Clear
Move lever to ON >>> red indicator is flashing
Rotate dial to nearest current time (if it's 7:20 pm, rotate dial to 7:30pm)
Press the dial once to set current time > red indicator light goes off
Do not accidentally press dial or it will set the wrong time....ok we know that
4) overlapping programs/
Make a chart of the times you want to program with ON and OFF plus am & pm
Check your chart for overlapping times that tell the timer to do more than one thing
Rotate dial clockwise to the first ON time >> pay attention to am & pm
Press button and first ON time is set
Rotate dial clockwise to the first OFF time >> watch the am and pm
Press button and first OFF time is set
You can have 48 on-off times >>> which seems a lot for a 24 hour repeat timer
5) try the timer with one program
6) If timer still doesn't work, put switch back in and see if lights turn on that way >>> it could be a loose wire suddenly cropped up
Last step >>> timer is no good, you need another one. We tried.
Testimonial: "Thank you, I followed your instructions and the timer is working properly."
How can the orbit mdoel 57894 be progrmed for multiple start times?
The product manual is confusing... how do you set 1-5 am and 2-12 pm and 3-5 pm? The manual says to press program button to choose A B or C programs, but does not give steps for programming or when to press enter to confirm setting... or say which position the dial should be in when programming.
57894 lets you program separately for each station...turn dial to Run Time and use arrow keys to select a station. Press enter or arrow keys to advance to next station.
57894 offers 'select a station', 'pick days of the week or interval between watering for that station', 'duration of watering for that station'. But picking days of the week is not the same as setting exact times 1-5 am and 2-12 pm.
The dial is set to auto for programs to operate..
Don't forget to activate battery located top right on face of timer.
http://waterheatertimer.org/pdf/Orbit-57894.pdf
So the 57894 has more options than a 24-hour analog sprinkler timer that repeats same cycle each day with 14-day-skipper.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have the UPM ETW 350 user manual. It is easy to follow up to and incl. setting on time BUT setting off time is a mystery. Is there a 1-800 nu. I can call to be waled thru?
http://waterheatertimer.org/UPM-timers-and-manuals.html
This line of timers has mostly disappeared from market... I do not know who is offering tech support for the product.
If you purchased the timer recently, it may be previously used or non-functioning.
The manual is complicated and incomplete ... probably because they have built-in or intuitive steps that display when you program the timer... or they assume you want to fiddle around with their product.
It appears the timer must be wired correctly prior to programming.
http://waterheatertimer.org/How-to-wire-timers.html
- you set the current time first... you toggle through menu choices using arrow keys... go to clock...press set.. toggle to find current day (today) and then press set button... then do the same for hour and minute... pressing set button to confirm each selection.
- to program... you toggle through menu choices using arrow keys... when 1 ON appears on display... press set... select day or days for program 1 on using arrow keys... press set... select hour and minute... and press set after each to confirm selection.
These steps confirm setting for program 1 ON ...the day hour and minute that program 1 turns ON
Each ON program requires OFF program..
Probably the timer automatically displays program 1 OFF as soon as program 1 ON is set... then you follow same steps to select day, hour and minute for program 1 off.
Repeat steps to set up to 20 programs.
Do not touch buttons for period of time, and the timer probably displays current time and is ready to go, but manual is unclear about setting the mode..
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
Gene
How do i set the system to run 2 times per day
You have multiple start times in 1 or all of the programs A,B,C or D. 1 start time in the A program will run the zones in this program once on the days it is schedule to water. Example: Think of each program as a separate timer. All want to know 3 things What time to water, how long to water for and what days to water. Timer 1 is the A program. Set to water everyday at 8 am for every zone which has a duration. Don't want the plants to water everyday take the minutes out of zone run time in this timer or the A program. Want the plants to water M,W,F add a start time, a run time to corresponding zone and M,W,F in timer 2 or B program. Want the plants to water twice in a 24 hr period add a second start time to each timer or program. and so on. The programs are only used for watering schedules with more or less days per week you want a specific zone to water. Otherwise use only the A program with 1 start time for once a day or whatever days you desire for all zones.
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
http://www.sunvic.co.uk/documentation/Programmer_Select_207.pdf
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
40helpful
Vigoro 196-036 water timer manual -- need instructions on how to set timer for the Vigoor 196-036
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Have set the timer to come on at the same time every day and off at the same time every day but when I put it Auto mode does not turn on. What step am I missing
You posted under GE dial-type power strip timer.
GE has 2 different models: 57698 & 15090
15090 has instruction manual, and 57698 doesn't.
http://waterheatertimer.org/GE-timers-and-manuals.html#57698
GE also makes 15077 digital power strip timer:
The digital power strip has Auto mode.
1) If programming has overlaps, or if programs are set for conflicting days, then timer will not operate as expected. Review programming steps by pressing PROG button.
2) If current time is not set, then programs will not operate. Press and HOLD clock button while setting current time.
3) I test timers, and sometimes manuals are confusing so I write out the steps to make sure I understand correctly.
4) It is possible that timer is defective.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
For GE- 15117, Mode acts as a controller called "an On or Off override..." "or sets events to Automatic or random" Random = a +/- program shift (that's understandable). You'd think...
I cannot make precise sense of your question.
However I agree, the manual for GE 17117 is not clear.
1) A number of folks are writing in about this particular timer, with same MODE problem as you.
Some folks, the timer skips over auto.
Some folks the timer just doesn't come on.
Facts are facts, some timers are busted on arrival.
But let's look at the problem from three different directions and see if it helps:
2) Steps from manual:
When you finish programming, press clock button to return to current time.
Next set MODE.
Press MODE button and timer enters override ON-OFF. Override reverses whatever program is operating at that moment.
Press MODE button again and timer enters RDM random mode, and lights turn on-off randomly.
Press MODE button again and timer enters AUTO >>> auto is correct setting that lets programs run.
Here's the trick: after setting MODE to auto, press clock button again and current time displays.
If timer will not perform these steps, then timer is suspect
If timer performs these steps, but programs won't work, the timer is suspect or programming is suspect.
3) Check programming for conflicts and overlaps that cause timer not to function 'as expected.'
Some timers skip over conflicting programs, some timers simply stay on, others stay off.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
Example of conflict is event1 ON at 7am TU > but event1 OFF at 11pm All-days. Both event1 ON and OFF events must have consistent days >>> so change TU to All-days.
Another example is event1 ON 7am OFF 11pm TU >> but event2 says opposite, or has overlapping times.
I suggest folks make a schedule of programs before starting.
To review and change programs, start with current time showing in display: Press PROG button and scroll through event1 ON, event1 OFF, event2 ON, event2 OFF, etc.
Write down the events and make a chart.
Look for overlaps, and check for days of operation, and make sure each event ON has corresponding event OFF
4) If events are correct, and timer MODE button functions, but timer still doesn't work, the final suspect before calling the timer busted, is circuit problem. Use circuit analyzer on receptacle. Or plug timer into receptacle on different breaker and see if problem persists.
1helpful
Utilitech self-adjusting wall timer 0192773. I hooked up the timer (4 wires). The automatic modes does not work and will not turn on and off the lights on set times. All it will do is turn lights on and...
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
I have been testing the 0192773, and other timers, for wire and program difficulties.
Good news: your timer is wired correctly. This timer will not operated lights with incorrect wiring.
programming steps are long, but same as other programmable timers.
The 0192773 is a 7-day or sunrise/sunset timer
1) Most programmable timers will not 'work as expected' if there is a conflict in programming.
They suggest you make a schedule of times before programming
2) One of the things this timer offers are individual days -or- groups of days > for example weekend only -or- weekdays only -or- all days of week -plus- individual days. For me, it was a bit confusing keeping that straight while programming
3) Each Program has ON time and OFF time
So Program1 ON has to be set same days as Program1 OFF
4) The other difficulty was how fast the display shifted back to current time when I was programming. If I looked at the instructions for a moment, my display would change before I could catch up. So it's possible that an ON or OFF time could be missed easily.
5) Finally, if you are using the timer as a sunrise/sunset, you need to enter Sunrise or Sunset with program1 ON and program1 OFF
I think the problem is in your programs:
You can use paperclip and hold in reset button for a few seconds and start over
Or
You can press PROG button and and re-check and re-set each program.
By the way, when setting current time, I noticed the timer let you chose a year up to the year 2099. I thought that was an optimistic outlook for both operator and timer.
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
