Question about Amana Refrigerators
I have an Amana fridge on top freezer on the bottom unit with an ice maker. If I have my ice maker feeler arm up so it is shut off both fridge and freezer work great. The second I push the arm down to make ice it trips the gfci? What do I need to check
    Passionate:
    Visited the website for 10 consecutive days.
  • 164 Answers
Your ground take it off the ground fault plug. Fridge is too much for a ground fault
Posted on Aug 13, 2018
SOURCE:
  • 1073 Answers
SOURCE: Bottom Mount Fridge
if it has a feeler arm it will look like a wire the size of a metal coat hanger it is on the right side of the icemaker if it is up pull it down to start making ice
Posted on Apr 25, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
seabreezehvac@yahoo.com
Posted on Apr 20, 2009
Maytag317
  • 1136 Answers
SOURCE: feeler arm on ice maker prevents freezer drawer from opening
Hi, There is no adjustment on the level arm other then bending it. Is it posible that something snagged it as the drawer was being pulled out and bent it? The arm should collapse all the way down tothe side of the icemaker and level with the bottom of the icemaker.
Hope this helps. Please let me know if I can help further.
Vic
Posted on May 11, 2009
  • 212 Answers
SOURCE: amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Posted on Jun 21, 2009
projdoc
  • 2237 Answers
SOURCE: 2000 Amana BX21Vl fridge: ice maker and freezer not working.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of. after the freezer freezes again, your ice maker will work again.
Posted on Aug 28, 2009
How do I turn off the ice maker in my Amana refridgerator?
There should be a stiff wire arm above the box where the ice cubes are stored. Gently lift the arm up until you feel a little jump. Let go of the and it shoould stay there. That turns off the ice maker. If the wire arm drops back down, lift it a little higher until it stays up. If you are going to move the fridge, make sure the water hose in back of the fridge is turned off and disconected or you will have a mess to clean up. When you want to turn it back on just lower the wire arm,
Nov 17, 2012 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Amana bottom freezer, model abc2037dts, there is a motor noise that goes on for 8 seconds then shuts off, then a few clunks for 2 seconds
Even if you do not have the water hooked up for the dispenser and ice maker, the fridge still makes the sound as if it is filling up the ice maker. If you lift the metal arm beside the ice maker, the sound stops happening because it thinks that the ice bucket is full.
Aug 08, 2010 | Refrigerators
Ice maker arm in freezer
On most automatic ice makers the arm is in the up position to make ice, but check with the manufacture to make sure
Jul 20, 2009 | Amana ABB1927DE Bottom Freezer...
Amana fridge ice maker not working
Jun 21, 2009 | Amana Refrigerators
Freezer Arm Not in Place
well in order for me to hep i would need the info all number on the back of the frig and i assuming u mean the ice maker arm is broke off or just missing so yes u need to arm for the ice maker to work so if u get the info off of the back of the unit and u can prolly go to amana's web site and buy the peice from them and install it yourself if u are unsure on how to install it might try and go to www.diynetwork.com and search on there site how to replace the ice maker arm good luck
May 12, 2009 | Amana ABB1927DE Bottom Freezer...
Feeler arm on ice maker prevents freezer drawer from opening
Vic
May 11, 2009 | Refrigerators
Dec 18, 2008 | Amana ARB8057CSR Bottom Freezer...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Bottom Mount Fridge
Apr 25, 2008 | Refrigerators
Refrigerators Logo
80 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
