Maytag Neptune MDG5500AW Gas Dryer
Problem for Maytag Neptune MDG5500AW Gas Dryer
Code on dryer panel
By thorntonk on Nov 25, 2007
8.8. code on dryer display
Same Problem
Dec 29, 2007
-   Same day with 8.8 display problem...3 hours later the panel changed to 50 minutes. Pressed start but unit only started for a second and then stopped, screen blank, then 50 comes back up. Same problem using the sensor start. Timed start didn't work once. Tried timed start and it's running now. Does this sound like a control panel issue?-   AZ Hat Lady
Dec 29, 2007
-   8.8 appears on panel - reset breakers with no luck, unplug with no luck. This is the third time this has happened. One time I could use the timed setting to get the unit to work and then the sensor worked fine for months. The second time the display came on after unplugging and sitting for 15 minutes. No solution this time.-   AZ Hat Lady
Dec 28, 2007
-   8.8. Code displayed on panel intermittently. Dryer starts after 5 or 6 attempts.
-   Guest
Best Solution
posted on Jan 03, 2008
Helpful)
MaytagWoes
Rank: Apprentice
Rating: 90%, 3 votes
We had a very similar problem. Replacement of the control board seemed to have fixed it.
Before replacing, you might want to visually examine the capacitors and resistors located onteh board. One of the two capacitors was leaking and the resistors had overheated.
Good luck.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune MDG5500AW Gas
Questions and Unsolved Problems for Maytag Neptune MDG5500AW Gas
Do you recommend Maytag Neptune MDG5500AW Gas Dryer?
Answer
Answer
Dryer starts to run warm air only, no hot air. Next load dryer runs cold air only.
Answer
May Tag Gas Dryer Neptune - TWhen started the air warms up but does not become hot. The next load... (More)
Answer
control panel lights up when door open, when door is closed all light shut off and work start
Answer
the control panel is dead, power is reaching the dryer, this can be seen when the dome light is on
Answer
my maytag mod# mde508dayw is drying the clothes but its not heating up its air drying them which has... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repairmen
in , AR
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
