Question about Campbell Hausfeld Plumbing
I am looking for a head gasket - Campbell Hausfeld Plumbing
    Genius:
  • 1,114 Answers
If you absolutely can not find the head gasket for your compressor or pump, you may be able to make one. I have done it on a few machines, in particular a pretty hefty old, old sears compressor.
Buy a roll of fiber gasket material (not the cork) from the auto parts store. Also get some gasket making sealent. Permatex makes one for high pressure applications. It's grey.
Method #1; Use the old gasket as template to cut out a new gasket from the fiber material. Use scissors and an exacto knife.
Method #2
Take the head and put it on a copy machine, and print out the picture. You may have to adjust the density.
Use the picture as template on the fiber gasket material (tape it down) and using scissors and an exacto knife, cut out the gasket.
You may need to study the head in relation to the gasket to determine any small holes etc, but this can work if you're neat and take your time.
Method #3
If taking a picture of the head does not show where the gasket needs to be cut in relation to piston block, there is another way to try this.
Get a roller bottle of ink used to re-ink an ink pad (office supply store). Roll out the ink on top of the piston block to show the outline of the gasket. You may need to clean the surface off with alcohol first. Place a piece of paper on the surface to transfer the ink. This will give you an outline to use as a template.
Smaller round holes can be made with a drill bit and drill, hole punch, etc. Trimming the gasket can be accomplished with a rotary tool(Dremel) , a fine file ,etc.
Make sure the head surface and block surface are totally clean of old gasket material.
Place a nice thin,even coat of sealant on both sides of new gasket, and bolt head down with even torque on all bolts.
Posted on Aug 03, 2009
Head gasket 1995 ford taurus 3.0 EFI
Daniel,
Here is an image of the head gasket answering "
What is the gasket supposed to look like". If you require more detailed information, then please ask.
Mar 18, 2014 | 1995 Ford Taurus
Pajero overheating
It sounds like you had a blown head gasket and it was leaking into the oil or into the exhaust and being burned. if you look at the oil on the dip stick it may look milky. if the head gasket starts leaking internally then it can / will cause overheating
Dec 02, 2013 | Mitsubishi Outlander Sport Cars & Trucks
Motorcycle oil leaking out of the head gasket
check the head gasket for problems. Re-tension the head
May 23, 2013 | Cars & Trucks
How do you replace the head gasket
with great difficultry, It is verry time consuming end verry costly to have it (Replaced)
Nov 27, 2012 | 2000 Kia Sportage
1987 toyota pickup with 22r keeps blowing head gasket
Your head bolts are stretched, when it got hot it weakened the metal in the bolts which means that the bolts cannot hold the needed tension on the head. Replace the bolts and you will stop blowing head gaskets. Also use Genuine Toyota head gasket, It will be a bit dearer but they are much better than aftermarket options.
Mar 07, 2012 | 1987 Toyota Pickup
Fix head gasket
For leaking head gasket it has to be replaced. For head gasket leaking and other troubleshooting, there are help links provided. Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------Water in engine oil? http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
-----------How to replace head gasket on car?http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket?http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century?http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
http://schematicsdiagram.blogspot.com/2011/12/location-of-head-gasket-on-1994-grand.html
HOW TO REPLACE A HEAD GASKET
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-head-gasket.html
How to replace Exhaust Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-exhaust-manifold-on.html
How to replace Intake Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-intake-manifold-on-acura.html
How to replace Cylinder Head ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cylinder-head-on-acura.html
Is it Easy to replace head gasket?
http://schematicsdiagram.blogspot.com/2011/12/is-it-easy-to-replace-head-gasket-on.html
Should I only replace head gaskets or complete head gasket assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
This will help. Thanks.
Feb 27, 2012 | Renault Cars & Trucks
Have changed head gasket etc. as thought was that but on start up to flush engine water was pouring straight out sum. nothing looked wrong in head gasket or intake gasket areas.
where is the watter coming out from? did you follow torque sequence / did you have head resurfaced? check block / did you find any thing wrong with the old head gasket? please give more info, so we can give you better assistance , Thank you for using Fixya.
Apr 10, 2010 | 1988 Subaru Justy
Water in the oil
you got a cracked head or head gasket a head gasket you can see where the warter was geting by blown head gasket cracked head is hard to see sometimes or have the heads checked or buy rebuilt heads from napa or autozone or ?
Mar 20, 2010 | 1995 Buick Regal
Suddenly started smoking white smoke and seems to be losing power
White smoke is coolant being burnt. That with your lose of power would suggest a bad head gasket. A compression test could confirm it. Hope this helps.
Nov 25, 2009 | 1995 Plymouth Voyager
I have a coolant leak in my 1995 camaro. The mechanic said it was where the timing cover meets the block. He said it looks like a gasket, and it is a hugh job to fix. What should I do?
It sounds like a head gasket.Do you overheat? Boil Over? If you do it is the head gasket.It is a big expensive job.There are sealers I have used available only online Seal a Head worked great.There is a test called an Engine sniffer that can positively confirm a bad head gasket.You must confirm.Look for my response on other overheating,Head Gasket issue on this site.Good Luck.
Sep 21, 2009 | 1995 Chevrolet Camaro
Plumbing Logo
128 people viewed this question
Top Campbell Hausfeld Plumbing Experts
Donni Steen
Tom Chichester
Are you a Campbell Hausfeld Plumbing Expert? Answer questions, earn points and help others
