Question about Frigidaire FDB1502RGC Built-in Dishwasher
The water comes back in the dishwasher after the cycle is done
  • 10,865 Answers
Actually your dishwasher is not completely draining. There are a few possible reasons for this. I will describe them so you can isolate the problem"
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Aug 02, 2009
On my Kenmore Ultra Wash Dishwasher model 665 the Normal Wash light is blinking even though the previous cycle finished successfully. Also I can't start the dishwasher -- it doesn't respond to any of the...
http://appliancejunk.com/forums/index.php?topic=2933.0
Hi. please find above your service and repair manual, below is a self help how to repair your dishwasher website, between the manual and the self help site, you should be able to isolate and repair your issue. You may have a blocked pump, or a faulty sensor, but there is no way of knowing until one performs the troubleshooting steps to isolate the problem.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Sometimes this fix works below, it's always worth a try?
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Jul 07, 2010 | Dishwashers
My dishwasher fills, but won't start running. it just sits full of water and just hums.
Apr 14, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
Dishwasher pumps even with power off
Mar 28, 2010 | Viking 24 in. Professional Series VUD040...
My Whirlpool GU24--XTPQ7 is suddenly not seeming to rinse our dishes well enough, they almost feel like the dish soap has left a baked on film, I guess when the heat comes on, it bakes the unrinsed soap? I...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Feb 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishawasher drains but right after lets all the
The check valve might be stuck. The valve is supposed to let the water out but stop it from flowing back in. Also make sure you discharge line has a loop. And check your air gap at the sink(if you have one) and make sure it is not plugged.
Aug 04, 2009 | GE HDA3500NWW Dishwasher
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Hi, If the drain hose is attached under the sink, make sure that the drain hose is looped higher then the outlet it is attached to.
Most model will hold a small amount of water after draining to keep the seals moist.
I hope this helps.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Dishwashers
Water stay in .
Please post back here what the manufacturer and model number of your dishwasher.
Also, approximately how many years old is your dishwasher?
Can you be more specific with your problem?
If water remains after the cycle is done:
Is the water clear/clean?
How much water is left? More then 2 inches?
Please post back here with your findings, OK?
Apr 16, 2009 | Dishwashers
Inch of water left in bottom of dishwater after done running
check for blockage starting at air gap and disposer.trace back and clean
Dec 31, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire FDB1502RGC Built-in Dishwasher Logo
264 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
