Question about Panasonic PV-M1349 Combo
Remote code for PV-M1349
I have verizon fios and cannot get its remote to control this model panasonic pv-m1349....please you have the correct code?
    Problem Solver:
  • 6 Answers
Re: remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Posted on May 01, 2008
Re: remote code for PV-M1349 - Panasonic PV-M1349 Combo Combination Televisions
Need a code
Posted on Sep 04, 2012
0 characters
3 Points
Remote control code
I am getting a big black box on tv and don't have remote how do I get if off on a pv-m1349
Nov 08, 2013 | Panasonic PV-M1349 Combo
No Comcast remote code for Panasonic PV-C2062 - HELP!
On most universal remote control, you will find the procedure to enter the builder code OR a procedure to pass through all the code of the remote, one by one and pass to the other TILL you find the right one. It happen to me numbers of time because all my family ask me to do this...
Aug 15, 2009 | Panasonic PV-C2062 20 in. TV/VCR Combo
How to change panasonic tv from UHF to VHF
UHF is only the higher air channels, all you have to do is put on cable and scan.
Feb 27, 2009 | Panasonic PV-M1349 Combo
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Combination Televisions
Manual code to program remove for panasonic pv m2023
The remote control for Panosonic model 2023 does not work from a distance. But it works close by
Can you help?
Nov 15, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Tv Combo will not work with replacement remote
my panasonic tv model no. PV-DF2704, program light is blinking and I don't know how to cut it off. It is causing my tv to cut off. My remote control will not work. I bought it second hand. I program a universal remote and it works for a little while, but I can not set my tv for cable. Please help me if you can.
deborah from Louisville
Nov 12, 2007 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Picture too dark
if u hav a remot for it it shoud hav a screen ajust. ther is a pictur of a sun press it 2 times. if that dosnt work press it agn
Aug 06, 2007 | Panasonic PV-M1349 Combo
Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Sep 11, 2006 | Panasonic PV-M1349 Combo
Panasonic PV-M1349 Combo Logo
1,048 people viewed this question
Top Panasonic Combination Televisions Experts
Jaime Hernandez
Are you a Panasonic Combination Television Expert? Answer questions, earn points and help others
