Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Brushes stop rolling when against carpet, yes it is out of the upright position and when I left the base off the carpet the brushes start to roll again. What is wrong?
  • 10,865 Answers
Your belt is stretched out so it just stops when the carpet resists it. Get a new belt made for your particular machine and you should be back up and running
Posted on Aug 02, 2009
The beater bar on the dc51 will not work what do I do
HI, it's Jim from Crucial Vacuum!
If you're having trouble with your DC51 vacuums brush roll here are a few things to check for to resolve the issue.
Be sure that your Dyson DC51 is reclined and not in the upright position when testing the brush roll and if you have the option set the vacuum to 'Carpets' and not 'Hard Floors'
Look for noticeable debris stuck in the brush roll such as hair, or strands of carpet fibers. Remove these blockages with a razor or scissor.
Lastly, apply WD40 to the bearings of the vacuum to help against any resistance the brush roll may be experiencing. When a brush roll hasn't been replaced after usage, the bristles get worn and
You can purchase your replacement Dyson DC51 parts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=DC51&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 21, 2014 | Vacuums
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Why does The beater bar on my hoover continue to run in the upright position?
Hi there! Some vacuums do not come with the feature that automatically shuts the brushes off when in the upright position.. If your unit is like this, be sure to put the vacuum on the highest setting when using the hose. Also, because the brush-roll continues to spin, avoid tipping cleaner or setting it on furniture, fringed area rugs, or carpeted stairs during tool use. Hope this was helpful!
Jul 21, 2014 | Hoover Vacuums
Why beter bar dosent spin while in the vaccum mode only in up right position ?
Hello! The air pressure from the motor is most likely spinning the brushes in the upright position. This vacuum has a brush-roll on/off pedal located on the left side of the cleaner. To activate the brushes, power the vacuum on, recline the handle and then press the brush-roll on/off pedal. The brushes should begin to spin. If they do not the belt may need to be replaced. Hope this helps!
Jul 12, 2014 | Hoover Vacuums
I have model#UD40350 total pet compact. The lower vacuum brushes don.t turn.
Hi! It sounds like you have a broken or stretched belt. The belt controls the brush roll. If you are using the vacuum on carpet, you need the brushes to spin to agitate the carpet fibers. Below are step-by-step instructions on how to replace your belt. I have also included a link to the instruction manual if needed.
1. Lay cleaner flat and flip to expose nozzle base. To remove nozzle guard, use Phillips screwdriver to remove the screws.
2. Lift and remove brush roll and dispose of old belt if you see one.
3. Slide belt (style 19) onto motor shaft.
4. Place new belt on area of brush roll without bristles.
5. With new belt in place, pull and slide brush roll into nozzle making sure that the brush roll end caps are in the correct orientation.
6. Replace all screws to replace nozzle guard.
http://dirtdevil.com/file/898/
May 06, 2014 | Dirt Devil Dynamo Pet Bagless Upright...
Hoover model U6425-900 brushes do not roll
-- Make sure slide switch is in carpet position
-- The idler arn which tensions the brush belt may be broken
-- The idler arm override which is attached to the carpet slide switch may be broken
The second one is common.
Oct 30, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
My vacuum doesn't have any suction from the floor, only from the handheld attachments. I've cleaned all of the filters with no luck. Any suggestions?
With the vacuum plugged in and running, make sure the brush is spinning and that the brushes on it and long enough that they brush against your hand (or in real terms your carpet). If it is not spinning, replace the brush roll. This will also drastically increase the cleaning ability of it since the new roll will spin faster and the longer brushes will agitate your carpet better.
Let me know if you need more help,
chis
Jun 10, 2010 | Dirt Devil Reaction Twin Cyclone Upright...
How is the V-belt tension adjusted (Hoover Model U6439-900)or how do I know if the tension is correct? There seems to be a lot of "play" in the belt and I'm wondering if that is the reason the brush roll...
The V-Belt is not adjustable. There are two ways the belt has no tension: (1) when the handle is upright, a mechanical lever takes the drive tension off the belt, and (2) the brush roll lever setting you described. The upper handle would have to be in the floor cleaning position to check the belt, not in the storage position.
Oct 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
166 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
