Question about Bionaire Dryers
I just want to know the wire color code for a bionaire window fan motor
I'm replacing fan motor and I need wire color code
    Top Expert:
  • Bionaire Master
  • 52,787 Answers
Contact Bionaire directly and request the color code.
Posted on Aug 12, 2018
SOURCE:
SOURCE: how to set the temperature
Look up this fan on amazon.com. In the comments/reviews a gentleman posted instructions for fixing the thermostat (it involves opening up the fan and repositioning the thermostat wire).
Posted on Aug 11, 2007
jumptrout51
  • 3361 Answers
SOURCE: need a wiring diagram for emerson k55hweym 3739
green is ground. white is common. blue and orange are hi speed/low speed. brown goes to the capacitor.
Both motors should have the wire diagram on the side of the motor.
Posted on Jul 04, 2009
  • 37 Answers
SOURCE: need to know what the wire color corresponds to
red doesn't necasarraly mean anything check with peterbilt service or parts dept
Posted on Mar 17, 2010
  • 351 Answers
SOURCE: wiring code for ceiling fan
These fans do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
Posted on Jun 04, 2010
  • 32 Answers
SOURCE: I have a carrier unit
Look inside the panel,there should be a wiring diagram
Posted on Sep 16, 2010
Ceiling fan speed chain broke off while fan was off. Replaced the 3-speed 4-wire switch with same type and rewired as before. Now fan only has 1 low speed. Could capacitor have gotten damaged?
capacitor tis toast. Have done what you did once. Just remember if/when replacing it...
The capacitor leads are color coded but the motor leads may not be! Tag the motor leads with colored tape before disconnecting the old capacitor, if necessary. Been there too! Differ by brands whether they are color coded.
Feb 25, 2018 | Hunter (25417) Ceiling Fan
Bionaire btf4002 fan motor wont run and shorting the brown and black wire to short the thermal switch will it run
Thermal switch is ng and needs to be replaced. That switch is designed to shut down device when it overheats.
Sep 05, 2017 | Bionaire Heating & Cooling
Bionaire BF1209R motor possibly burned out from a string caught in blades What are some solutions besides getting a new fan
The motor has a fuse buried in the windings near where the wires connect to the motor. Sometimes, if you're careful, you can expose the wires and jump around the fuse. Otherwise a new motor in in order.
Feb 23, 2014 | Dryers
Fan switch for fan light combo
Unfortunately, there is no standard color coding for ceiling fan wiring. You note in your video that the replacement switch has an L(ine) terminal and there should be 1, 2, and 3 terminals as well for controlling fan speed. Check the switch you are replacing for similar marking. If you are in luck, you can replace by L and numbers rather than colors. I checked my entire file of fan installation information and nothing more explicit is provided
May 24, 2013 | Photography
The lights come on but the fan blade doesnt turn
Check the thermal fuse located inside the motor fan winding wire. Check the crystal oscillator and micro-controller located in the printed control board of the fan. When it is replace with similar type, the fan will function again and ready to be use.
Thanks for asking.
Jul 09, 2011 | Bionaire BSF1731RC Stand (Pedestal) Fan
Electrical box has one red and one black wire and the switch has two balck wires and a green wire. How do I connect them?
If I understand correctly, you are replacing a switch that has a black and red wire?
And your new switch has 2 black wires + green wire
The green is color-code for ground, and it always connects to bare ground wire.
The switch wires are not color-coded (both are black) so they can connect to either of the two wires that came off old switch.
If switch does not operate, they try reversing the two black wires.
As a general rule, the wires inside your box are color-coded.
The color-code information says:
The black is the Hot from breaker box. This wire carries electricity from the breaker to the switch.
The red wire goes to Load (fan, light, motor). This wire carries electricity to the Load when you turn ON the switch.
Oct 23, 2010 | Solar Leviton Decora Sureslide Dimmer...
Blower motor not working for heat and air conditioner. need fuse locations and wiring color code to trace circuit
I've had this problem before too...first check to see if your fan can be rotated by hand (make sure the car isn't running while checking). If you can't spin the fan by hand, then you need to replace the fan. The cooling fan has a 40A fuse in the fuse box under the hood (driver's side). If your fan has siezed, it will trip this fuse too.
Aug 18, 2010 | 1998 Ford Escort
Hi, I have a problem with bionair widow fan 2300, it´s the R1 RESISTOR, but the over heating erase the color code of the resitor, you can help me?...sorry for my english
There is a major problem with the fan's electronic board. There is most likely a shorted capacitor, or some sort of fried transistor somewhere. depending on your electronics know how, try troubleshooting the circuit starting with it's power supply/input. but depending on the price of the fan, and the amount of aggrivation, I would just get a new one. Remember, most of the newer appliances today are ment to only last a few years, then die. I don't care what it is. all the companies want to do is make them as cheaply as possible, so they can sell more of them, and make more money. so don't be surprised if you can't fix it. some things are just not fixable.
Aug 12, 2010 | Bionaire BW2300 Window Mount Fan
I need to replace my switch for speed an i dont how my wires go
mcdevito75 here, The wires in the instuctions should show what color they hook up to, now just match those wires with the switch, a small tip, hook up a dark wire from the fan motor to a dark wire on the switch, a lite color wire from the fan motor to a lite color wire on the switch as you hook up each pair or wires, cover the bare wires remaining on the fan motor and switch with tape and try the fan to check spped.
Jul 20, 2010 | Aloha Housewares (93645) Ceiling Fan
Dryers Logo
94 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Kardoc
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
