Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
KP-53HS30 NEEDS TO HAVE THE CONVERGENCE FIXED OR REPLACED CAN I DO THIS MYSELF?
  • 13 more comments
  • tarapur50 Jan 07, 2008
    yes, i have same problem here, also i have soldering experience, can u send me schematic and some tips to replace convergence ic?
    thanks.
  • Anonymous Mar 01, 2008
    green & red wavy lines flash focus how 2 work? need manuel
  • Anonymous Apr 01, 2008
    I had my convergence checked and the repair guy solved it by using the remote and it appeared he new a code. Can this be shared with me so I do not need to call him back.
    I am having a convergence problem I think with my TV. The colors are overlaping especially with the letters. It is under warranty and two months ago a service repair guy came to fix and did it all by using the remote control. Is it only a secret to him or can I find out the method to do it.
    How can I fix my convergence without having to wait for a repair man
  • jbiskup Jun 04, 2008
    I have the same problem, red is out of aliginment can someone let me know what to replace and where?and some tips to replace convergence ic? Also where to buy.
    Also let me know if it solved your problems
  • Jotelern Jul 13, 2008
    Yes, I think so...it's like seeing double and the color is off. Is this fixable at home?
    Thx
  • SONY938 Jan 03, 2009
    I think I have the same problem. Can you send me the schematic.
    Sony@carsonstewart.com
  • chatwithdan Jan 16, 2009
    can you send me the schematic as well. email is chatwithdan@comcast.net
    thanx
    Triple vision...multi colors...Where do I find the convergence setting in the menu of my Sony KP-53HS30
  • dongmin85 Feb 04, 2009
    The screen looks like 3-D.
    I have same problem. Can you send me, too?
    My e-mail is dongmin85@freechal.com
  • Anonymous Feb 11, 2009
    covergence off.
    Red and gree colour instantly off (convergence)
  • cube452 Feb 15, 2009
    It appears that I have the same issue going on here. When I opened the backside, I could clearly see the green and blue light spinning or working much faster then the red. I'm hoping for some help with what might be wrong, I don't want to have to replace this tv already. Any help with parts and schematics would be greatly appreciated. thank you in advance, Gerald
    cube452@yahoo.com
  • artbyjake Apr 15, 2009
    Could use the schematics too please, thanks so much!
    artbyjake@gmail.com
  • cleaner5525 May 08, 2009
    please email me a schematic for a sony kp-53hs30 tv at cleaner5525@yahoo.com
    thank you
    edward
Yes you can I did read around and you can order converg IC's and replace them along with maybe a fused resistor. I can e-mail you schematic just leave a message here.
Posted on Dec 31, 2007
Please email me a schematic for a sony kp-53hs30 tv at
dboultonasr@aol.com
Posted on Apr 14, 2009
The imagen is distortion and has strips
Posted on Jan 26, 2009
    Problem Solver:
Hi, i seen your comment on fixya.com and i have the same problem with
my big screen tv if possible can u email me the schematics or how to make adjustments in service mode and any
helpful info. that u may have obtained to fix your television. any
help appreciated THANKS. deadamz@gmail.com
Posted on Jan 19, 2009
Heard for this model the IC chips are STK 392-040
does anyone have the schematic?
i need to replace chips as well.
thanks
Posted on Jul 04, 2008
I have the same problem, can you e-mail me the schematics too at
junkkhut@netzero.com
Thanks,
Junk Khut
Posted on Jan 10, 2008
  • Sony Master
  • 3,459 Answers
Yes - You can do it yourself. On the Sony Tv its a fairly easy repair.
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 22, 2009
My colours are overlaping each other and some times the picture is visible and some times its like crazy 3d colour effects.
i been told it could be my convergence so can i request the schematics and is possible how to change the convergence (instructions)
highly appreciate it
thanx
asbutt@lakeheadu.ca
Posted on Mar 03, 2008
I have a Sony KP-53HS30 projection TV. The picture is clear for 2 minutes after I turn TV on after that the red color spreads around all light colors on the TV making it unwatchable. Is there a way I can...
Tv have a convergence problems,it dead.The tv convergence board is dead.The tv convergence board,must be replaced like 2 STK convergence ICS and some or all of resistors too.Will fix the tv convergence board,to solved tv convergence picture problems.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.
Mar 14, 2011 | Sony KP-53HS30 53" Rear Projection...
The same Convergence Problem
Click HERE to download schematics of KP-53HS30
Download all 6 parts of file and unzip it with WinRaR to get PDF file.
Jul 30, 2009 | Sony KP-53HS30 53" Rear Projection...
I have problems with my convergence, the picture shows on a oval shape. Its a Sony KP-53HS30
You need to replace two convergence out ICs STK392-560 in D board of TV.
Above said ICs are available in Parts Store.
Apr 21, 2009 | Sony KP-53HS30 53" Rear Projection...
Picture appears out of focus
convergence problems I just fixed one for 225 there are 2 stk to be replaced you willhave to call a tech
Jul 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 Convergence Issue
Are both 3.15 amp fuses good ?................................T.
Dec 24, 2007 | Sony KP-51WS510 51" Rear Projection...
Convergance circuit board
you don't need a convergence board the one you have could be fix the only problem is the alignment is not that easy and won't cost $ 500 unless you live in alaska and worth fixing it today you just get bad set made in chi???
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP53HS30 projection tv looks 3 d
You have a convergence problem, was it moved lately? Did you try the convergence setting in the customer menu?
did you check all fuses get back to me
Oct 10, 2007 | Sony KP-53HS30 53" Rear Projection...
Double images--3d view--ghost picture Sony KP-53HS30
The convergence amps are the big STK's*** located possibly on the G-board in the sony. It is very difficult if you are not familiar with components and soldering, You can buy them at MCMelectronics, bluestar-online.com, Tritronics, VanceBaldwin.com, etc. Diagrams are online at fixya.com on the rightside of screen. Places like Manual.com or you can search the web. Hope this helps!
Sep 24, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
633 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
