Question about Toshiba Televison & Video
My old remote for my Toshiba tv broke. I now have omega 23113 remote control and need to connect to my tv
Batteries in pushed tv and power together but nothing happens
    Top Expert:
  • Toshiba Master
  • 52,782 Answers
Pushing TV, then POWER might produce results but if the Omega remote control is not compatible with your Toshiba TV you will continue to get no results.
Posted on Aug 11, 2018
  • Laurence Millar
    Laurence Millar Aug 11, 2018
    Thank you it's not compatable I hope to change it
SOURCE:
ctf1800
  • 4402 Answers
SOURCE: tv remote setup code for toshiba
Remote codes
http://www.remotecentral.com/index.html
Posted on Feb 22, 2008
SOURCE: Innovage Jumbo Universal Remote Control
If you don't have the code do this! I worked for me.... Hold code search until light stays on... then select item to program <tv, vcr, dvd,exct..>... then press power button once... It will blink every couple of seconds and run thru the codes it self..... wait for the item choosen to turn off.... Then quickly press enter... TADA PROGRAMED!!!!! continue for each item to be programed. Be patient there are up to 500 codes! Can take Up to 10 min, But better than wasting $10.00$ good luck
Posted on Aug 04, 2008
  • 56 Answers
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Posted on Jan 14, 2009
SOURCE: Philips remote control codes
Although Philips as well as a number of other sites advertise that they have a list of codes available on their sites I never found one even after searching for quite a long time. By sheer accident I ran into this site: www.lexrixa.com/remote-control.htm and they had the codes. Just to make me look like a real fool after spending all that time trying to find the code I happened to lay the battery cover down upside down and there it was all along. I had done that just in case I ever lost the manual. Evidently I was a lot smarter then than I am now.
Posted on Jan 29, 2009
  • 1214 Answers
SOURCE: Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Posted on Jan 31, 2009
Can you help, i have a toshiba tv (quite old, not flat screen) and i broke the remote control. I now have a [URC22S Universal Remote Controller] and I'm having a lot of trouble getting it to work
Please provide more details. What do you want to know. Setup codes? If so, check this site. Setup code list and setup proceedings to many popular brand remote controls are given.
Apr 22, 2013 | Televison & Video
Toshiba tv 20 yrs. old will not come on when remote control is pushed
It will be very difficult to get the spare parts to this TV as it is over 20 years of age. It will be best to buy a new one, and it will be a wise decision.
Nov 14, 2012 | Toshiba Televison & Video
Hello, My tv is not responding to the remote. Cannot change channels or do anything with TV because of this. TV is a month old
solution 1: try pushing the buttons on the tv, manually, and if that doesnt work, call someone to look at it, like a handyman or geeksquad
solution 2: change the batteries in the remote
Jan 30, 2011 | Toshiba MR120 Remote Control
The tv doesn't react when pressing the power button. What can I do to fix this?
Things You'll Need:
  • Batteries
    • 1 Press the "TV" button and then press the "Power" button on the remote. If the TV turns on, your remote was just switched off of TV mode.
    • 2 Reprogram your remote to your TV. Universal remote controls can be accidentally unprogrammed by sitting on the wrong combination of buttons or having the batteries disconnect from the inner connections.
    • 3 Unplug the TV from the electrical outlet for a few minutes and plug it back in. This will reset the TV in case a power surge caused the TV to become "confused."
    • 4 Replace the batteries with new ones. Do not use old batteries from a different device in your house because if the batteries do not work, you won't be able to determine anything because those batteries may not have enough juice to power the remote. Keep in mind that different devices have different needs, so the batteries may have had enough power for something else to work but not enough for your remote.
    • 5 Check the batteries to see if they are inserted in the right direction. It's possible that someone dropped the remote, the batteries fell out and then were inserted incorrectly.
    • 6 Press the "Power" button on the TV set to determine that the TV is not dead. A dead TV will not turn on from a remote.
    • 7 Program the remote to another TV. If the second TV works from the remote, the problem is with your TV's remote signal receiver
Jan 17, 2011 | Sony Rm-yd035 Remote Control
I can't program my Toshiba TV to the CT 91507 remote
change battrries and select our old remote control codes
Jan 19, 2009 | Toshiba CT-90157 Remote Control
Faulty Remote
Same thing happened to mine. I opened the remote and found that the springy wire that connects the negative (-) end of the AA batteries to the remote broke off. I soldered it back together and it works now. Soldering it back together was VERY tricky because the two ends were at a 45 degree angle to each other. It took a lot of patience and a steady hand.
Apr 04, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
35 in toshiba 35A44
unplug your television,then hold together the menu and the vol+.then press the power on,when its on release together the menu and the vol+ buttons
Nov 01, 2007 | Toshiba 35A44 35" TV
Remote Won't Work! Problem with TV remote receptor?
Try unplugging the set for 12 to 24 hours. if that does not work, theres a problem in the remote sensor circuit or the microprocessor circuit. its going to need a pro to fix it as it meeds trouble shooting.
Sep 05, 2006 | Toshiba 32AF41 32" TV
Toshiba TV Remote Control not working
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Jun 27, 2006 | Toshiba 32A30 32" TV
Televison & Video Logo
42 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
