Image burned into screen
Dvd player logo is burned into the screen
  • 10,865 Answers
Sadly there is no quick fix for this but it may fade over time.
Posted on Aug 02, 2009
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
There are marks on my LCD 42" TV ,its on the screen itself.It looks like water marks.It started of small marks and it then it getting bigger.
Things You'll Need:
  • Burn-In Reduction Screen Saver DVD
  • DVD Player
  1. Instructions
    • 1 Plug DVD player into your TV and power on. Make sure you plug the right component cables into their corresponding inputs on the back of the TV. This is usually done by simply matching the colors of ends of the cables with the colors of the input holes on the back of the TV.
    • 2 Turn TV to the proper input to display the DVD. Make sure there is not a DVD in the player.
    • 3 Place burn-in reduction screen saver DVD in the player. Allow a few seconds for the DVD to start playing. A pattern of white "video snow" will appear on your screen. The entire screen should be taken up with this patterm.
    • 4 Run the DVD for at least several hours; this will help wear the TVs phosphors evenly. Depending on how long the image has been burned into the screen, the amount of time you should play the DVD varies a lot. A good rule to follow would be to play the DVD at least four times the period the image has been displayed. If you have an image that has been on the screen two hours a day for a whole month, run the screen saver for at least 240 hours
Jan 17, 2011 | Televison & Video
I burned a video to a CD-R and it wont play in my DVD player
You probably burned an AVI file to disk using Image Burn or some program like that. Your DVD is probably older and won't accept anything but a true DVD. Buy a $30 player that's approved for DVD-R, XVID, MP3, etc.
Apr 05, 2010 | Samsung DVD-1080P8/XEU DVD Player
Hello, i burnt a dvd with the firmware update, and my player says data disc. why won't it work
Goto manufactures web site for proper burning settings, and firmware update process instructions.
Mar 15, 2010 | Pioneer BDP-51FD Blu-Ray Player
The dvd player is not reading disk
is it a burned disk?.
some dvd players can read a disk You burned/made but only if the DVD player has AVI or DIVX logo on it.otherwise they Will Not play a burned movie/DVD..
Aug 12, 2009 | Samsung DVD-P230 DVD Player
Firmwae upgrade & dvd's don't play on other players
You can download the firmware and burn it to a CD, not a DVD. I don't know what burning software you are using put with Nero you would choose to burn it as an ISO, This is standardized way of burning identical images of CD/DVD. You should be able to then put the burned CD with the updated firmware into the unit and it should automatically update. You can watch the TV screen and see if it prompts you for any info but I do not believe that it will. Good Luck.
Mar 24, 2008 | Lite On LVC-9016G DVD Recorder/VCR
Koss dvd player
As your DVD is screenless I think you see it on a TV or monitor.Pls make sure the company LOGO is displaying.If the logo is coming--it means video processor is ok--if not try it with resoldering.
Oct 15, 2007 | Koss DVP2161 Portable DVD Player without...
DVD player cannot read any DVDs. Says "Region Error"
I Just started getting this same error. All the way down to the "Philips" logo. I wrote to Yamaha to report the problem and all they would (or could) tell me was to take it to any authorized Yamaha repair center (Best Buy). I sure would like to know if you got any resolution to your question in Mar. If not, what did you do?
Mar 18, 2007 | Yamaha DVR-S120 DVD Player
JVC DVD player stuck in Split screen
the player is set to progressive scan mode.use relevant button on remote to reset to interlace mode. Duane,S/Africa
Mar 11, 2007 | JVC XV-N320 DVD Player
The image you see is burned in the CRT's,nothing wrong with
screens.As you might expect, red,green and blue CRT's are
very expensive,about 400.00 each.
Nov 14, 2006 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
269 people viewed this question
Top Televison & Video Experts
Electro Med Services...
