Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Clean behind screen
Need to remove screen spider got inside, what is esiest way
  • Michael Nov 09, 2008
    I think I have the same problem. I have a fog like blue micro dots all over the screen, It started in the bottom left corner and has progressed over 70% of the screen. This has happened over a 1 year timje frame. My TV is now a couple of years old. It started after I replaced the Projection Light.
    Is this the same as you have described? I will try to follow the repair discription given and will update later.
A repair man came out to my house and took off the back panel, he has vinager and water and a paper towel and just wiped it all out.
Posted on Apr 07, 2008
I have a 42 inch screen and have cleaned it myself. It takes quite a bit of contortionist positions but can be done. Remove the back panel and have a microfiber cloth handy. get some invisible glass glass cleaner.....It has no soap so it cleans well. Spray the cloth lightly and the rest is reach and wipe...It does take a long time. You can also clean the lenses.GENTLY.... If you have streaks after turning it on you have to keep working on it. I couldnt come out of the process without some streaks. Its just too hard to reach the whole darn screen..I hope this helps ya out
Posted on Jan 09, 2008
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
A spider is on the inside of the screen. how do I open the tv open to get the spider out and clean the inside of screen and lenses?
First gather your needed items: screwdriver and a helper.
The screen is mounted to the enclosure of the TV by hanging on tabs mounted on the enclosure inside behind the screen. The screen simply lifts off after removing it's set screws at the bottom of the screen behind the big plastic piece that is below the entire screen.
1) Remove the speaker covers (grills).
2) Locate and remove the screws that hold the plastic piece onto the enclosure (8-12).
3) Remove the plastic cover and you will see the set screws holding the screen.
4) Remove the screws (2-4).
5) Use your helper as your screen is really big for most average sized people and lift the screen including the plastic bezel up and away from the enclosure.
Ensure that you have a secure area to set the screen as it will be large, heavy but yet very delicate. Also, do not clean anything unless you know for sure that you need to as sometimes just by touching things they get misaligned or break. This means but is not limited to: mirror, lenses & the screen.
When reinstalling the screen ensure that you hang the screen back onto all of the tabs or the picture will be blurry.
Good Luck!
Sep 06, 2010 | Hitachi 57G500 57" TV
Spider webs behind screen
It might be that you have more bugs inside, but if you used a chemical to clean this, it's probable that it afftected the tvs functions
Aug 07, 2009 | Toshiba 56HM66 56" Projection HDTV
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
removal of the screen on this unit is not to difficult. to remove the screen you will need a t20 bit. the torx 20 screws on the back side of screen then the torx screws on front panel. be carefull that screen is easy scratched.
Oct 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Spiderwebs under Screen, how do i clean it ?
Yes, I have seen this many times. Usually the best way is to remove the upper back cover and clean out the spider webs with a soft, dry cloth, but be careful because the mirror is mounted to the inside of the cover.
Jun 24, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Trying To Remove Screen
I have a panasonic 53 inch and have had the same problem on numerous occasions. I removed the backing of the television, stuck my vaccuum cleaner hose inside the tv and sucked out the spider and the web.
Apr 29, 2007 | Toshiba 65H81 65" Rear Projection...
Sider webs
Here's my suggestion: I have a 55" Philips HDTV and I live in an area known for excessive dust and more than a fair share of spiders. I checked online and found that there are usually 1-4 access panels that can be removed for cleaning, repair, etc. Here are my steps: 1. Remove the upper most panel (usually a trapezoid-shaped plastic "box"). There are anywhere from 1-4 "hangers" that, once all the screws are removed, will hold the panel in place while you are unscrewing the last few screws. 2. Remove the panel and clean with a lint-free cloth the entire inside of the panel. This is an area where a lot of dust and spider webs can be found. 3. Grab your vacuum cleaner and carefully clean away all the spider webs. Making sure you don't bump into the inside of the projector screen! 4. Spray a small amount of dust cleaner or window cleaner on the lint-free cloth and run the entire length of the TV. Clean all surfaces this way except the reflector (mirror). It is best to clean the mirror with compressed air (get it anywhere - usually in the computer section). 5. Using a flashlight or bare lightbulb, thoroughly inspect all surfaces for dust and spiderwebs. And, of course, clean anything missed the first time around. 6. Using a clean lint-free cloth (I find cotton underwear from Wal-Mart works the best), spray a very small amount of window cleaner (streak-free Windex, etc.) on the cloth and rub the cloth together until almost dry. Then, simply wipe all three lenses clean. 7. Replace the back panel and pay close attention to the alignment of the holes to ensure the screw goes back in the same way it came (if not, the panel could ultimately lose the seal and allow for more dust). 8. Allow for several minutes drying time before turning the set back on. Hints: 1. Clean the speaker area, too. 2. Repeat the process at least each 30 - 45 days to ensure optimal performance. 3. Use a small computer fan to circulate air behind the set if the area gathers excessive dust. They're quiet and can be purchased (almost anywhere - Radio Shack, Wal-Mart, etc.)with switches that are easily accessible.
Sep 01, 2006 | GE 46GW947 46" Rear Projection Television
Clean inside of the screen? Spider webs?
You should get the service manual so you dont take apart something you shouldnt
Aug 24, 2006 | Panasonic PT-61HX40 61" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
