Question about Hunter Ceiling Fan Light Switch Control
Had a fan/light combo controled with a single wall switch.Turn wall switch off and the fan and light would go off or, if wall switch was on light/fan could be turned on or off by chains. There is no power going into wall switch box. Power is being run into ceiling box. I bought new fan and dual control switch and ran 14/3 wire from ceiling box to wall switch box. I took out the old 14/2 that use to make this run. I can not make the fan/ light wwork now from dual wall switch. I could control fan speed but light wold only work when fan was running. i can not figuer out how to hook up the wiring.
  • 8 more comments
  • cohelp Aug 02, 2009
    Thank you for the fast reply. The new switch is a Hunter dual control 27182 with two sliding knobs. One sliding knob for light brightness one knob to control speed. It has three wires,black,blue red. The fan which is a hunter also has a black, white, striped and of course green for ground. Any idea how to hook up. I have wired fans with dual controls before but the power was always coming into the wall switch box. Thank you.
    1) black goes to hot..... blue goes to fan..... red goes to light
    2) 14/3 has red, black, white ground.
    The second time I hooked up the wires the fan came on even with the knob turned "off"
    The first time I hooked it up I could control the fan speed but the light would only come on with the fan running.
    1) black
    I'm sorry.yes red,black and white are coated. Ground (copper) is not. It is romex.
    I'm sorry light fan wires don't say what they are for. Instructions only say black goes to black, white goes to white green goes to bare or green and the striped wire goes to the wire from the wall switch.
    The blue,red and black wires I mentioned before were from the switch.
    No screws on wall switch. My last e-mail might have crosses your last comment. Sorry...... wall switch has three wires. Black goes to hot........blue goes to fan.....red goes to light.
  • cohelp Aug 03, 2009
    I will try this......... Why is there not a way to wire the fan/light to the dual switch? This is the first time I have put in a fan that does not have the power going to the wall switch first.
    In the old wall switch box there was only one 14/2 romex coming in and that was from the ceiling box. the house was built in 1954 and I can only assume that there was only a light in the ceiling.The owners we bought the house from must have put up the fan/light combo which was turned on by the wall switch and then you could use the chains for the light/fan. There is another 14/2 romex in the ceiling box which goes to the light in the ceiling in the next room which is controled by a wall switch.
    Got it hooked up per your instructions. I can turn light on and off and control its brightness from wall control by moving knob up and down. The fan I have to turn on by pulling the fan chain. The fan control knob on the other side of the control switch does not work as you mentioned it would not.The light chain is there but no need to use it. I guess this is better than nothing. I'm glad it's a low ceiling. So ....... there is nothing I can do to get the control knob for the fan to work???
    Great effort made to help me. Total solution out come was not what I was hoping for but you can only do so much. Very helpful and took time to understand me. Thanks.
  • Hunter Master
  • 6,674 Answers
Your previous hook-up was probably using hot wire (black from ceiling) to go to switch, and white (neutral) to come back to fan, or vise versa. So if your new switch at wall only has 2 terminals to connect to, do same thing, go from your hot connection ( black) at ceiling where power coming in, to one terminal on switch, then bring white from other terminal connected to switch back & connect it to hots on ceiling fan. (it's like a continuation of hot wire, so tape it black at that end so you remember & warn others too) Then simply connect white from power coming in to neutral on fan connections. Connect Bare copper to grounds at light/fan. Understand? Let me know how you make out.
Posted on Aug 02, 2009
  • 11 more comments
  • Mike Butler
    Mike Butler Aug 02, 2009
    2 questions. 1- what does your instructions for light/fan say each wire is for, as in color and what it does.
    2. The new power wire/cable you ran back down to switch from ceiling, how many wires total in it that are coated & what colors?
  • Mike Butler
    Sorry, just to clarify, red and black are coated, is the white also coated?
  • Mike Butler
    Sorry to keep asking questions but need to know, what & how many screws does wall switch have on it for connection terminals ? What about any wires coming out of switch?
  • Mike Butler
    Sorry just read what you said earlier about switch, back soon.
  • Mike Butler
    Sorry, last comment about wires at fan, changed the plan, get right back to ya'
  • Mike Butler
    Mike Butler Aug 03, 2009
    Ok lets try this, Appears you only needed 2 wire for that light/fan, but whats done is done & you may use extras later .
    Here goes.
    Connect black incoming power source to light/fan black, as instructions say, but add another short piece (jumper wire) of black to connection & join it to black going down to switch.
    Connect white from source to white at fan/light.
    Now Connect red wire on switch to red wire on your new cable & connect it up at light to striped wire.
    Tape end of blue from switch good, as you won't need it, and don't connect white on new wire going down to switch to anything either, just tape end of it as well.
    The set-up you have will only work this way it appears. Let me know you understand what we're doing here.
  • Mike Butler
    I'm thinking this fan/light has chains to pull as well? Correct?
  • Mike Butler
    This should give you fan control by pull chain, and light will dim with switch.
  • Mike Butler
    Sorry, green to copper (ground) at light.
  • Mike Butler
    It sounds to me like your original wiring (correct me if I'm wrong) took power from ceiling connection where fan was and brought it down to switch. Was there only one 14/2 wire in that switch box when you removed old switch? Do you have a continuity tester, or voltmeter there to use? If there was 2 wire cables in switch box, hold up on that hook-up, and get back to me.
  • Mike Butler
    Yes that's what I figured. Basically sounds like you have line running across ceiling, then everything on that circuit is tapped into from there. So in old connection they would have run hot (black) from source down to switch via black wire, then back up from switch on white wire, (which is now really other end of black or hot, with switch in between) and connected it to black on ceiling fan.
    Does new fan/light have any pull chains?
  • Mike Butler
    That striped wire at fan only allows for 1 thing to be controlled by knob, which it usually the light rather than fan, as speed switch is built in to fan, and light is either on or off. Keep your eyes open for a fan that will allow both to be regulated by type of switch you have. No chains, usually just a fan direction switch on it. You can also buy a remote control unit that has sensor you wire in under cover at top of fan at ceiling, and work it that way.
  • Mike Butler
    If anything else I can help with , let me know, and I would appreciate you taking a minute to do rating on this when done, if you would. Thanks.
What is the correct way to hook up a TM813-WCCS? I have one lead from the downstairs 3-way switch - black/red/white, and a fan lead - black/white. I can get the 3-way switches to work, but no luck adding...
Not enough information is given.
TM813 is combo switch with single-pole and 3-way. So switch has two different rocker-switches on face, and one controls 3-way circuit and one controls single-pole circuit.
You are controlling a light and a fan.
You have successfully connected lights to 3-way switch.
Are you trying to connect fan to single-pole switch?
Add a comment and say what you are connecting, and what type of switch you are replacing, and what each wire tests, and what terminals are on switch and what wire you have connected to each terminal so far.
Jul 10, 2011 | Electrical Supplies
I want to use a TM8111 swithch to control 3 devices. A ceiling fan/light combo, night light and a vanity light. How do I hook it up?
Following image has basic wiring plan.
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Each Load (light-or-fan) has to have separate wire running to switch box.
If night light is plugged into wall outlet, then a new wire will have to be added going to switch box.
Most night lights have built in photo eye, and on-off switch.
Add a comment for more help and include specific wiring and what you have tried so far.
Jun 14, 2011 | Pass & Seymour Legrand TM8111 Three Single...
We have the slider lutron dual fan control/light dimmer single pole switch and need to install it to work with our fan/light combo which also operates with a remote. How do you install the combo switch? We...
I don't think you can do what you are trying. The fan & light are on one circuit. Probably, originally, there was only a light fixture there. The fan/light is on a single circuit and the remote does the controlling of both units.
Now, you are trying to install a fan control and light dimmer but you don't have wiring for each separately.
You might be able to use one of the dimmer controls to adjust the output to the fan/light combination, but you can't control them individually, if I understand your wiring.
Gary
Dec 19, 2010 | Slider Lutron: Dual Fan Control / Light...
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
We want to replace our bathroom exhaust fan. We like the Harbor Breeze 'Rosemont' model at Lowes. It's a decorative combo fan/light unit. The unit is equipped with 2 13 watt (60 Watt incandesant...
It does not matter whether you turn on the switch or the switch is motion
activated, the light does not know who turns it on.
The switch must be designed for florescent.
What do you mean by proper base, you have a single gang wall box,
that's a box inside the wall, with the electric and a switch,
The gang could be single or hold 5 switches, which ever is installed.
Most all switches fill fit into any gang box.
Feb 08, 2010 | Dryers
Possible cross wiring
Whew! You'll need to trip the breaker that the fan/light is on and make sure that the circuit is dead. Turn the wall switch to "off". Gain access to your wiring connections at the ceiling. If you are operating the fan and lights via a single wall switch, proceed as follows: Your motor hot wire from the fan is black (usually, but verify all wire colors with your instruction manual, just in case they differ), and the light hot wire is usually blue. In your ceiling box, you will find black wires twisted together as well as white wires twisted together. Look for a single black wire that is not a part of the black twisted bundle. This wire will be the return wire from the wall switch and is the wire that will supply electricity to your fan and light when the circuit is powered up and the wall switch is "on". Connect the motor wire (black) and the light wire (blue) from the fan to the black wire. Locate the white wires from the motor and the light and connect these to the white bundle. Fasten all wires using wire nuts. Make sure that no parts of the wiring are left exposed. Electrical taping is a good idea, but don't let it be a substitute for the wire nuts. Be sure to connect the ground wire. Turn your breaker back on, and turn the wall switch to on. Verify proper operation of the fan and light by operating the pull chalns.
Hope this helps. Best regards, --WoobieDog--
Jul 07, 2009 | Hunter 52" Ceiling Fan With Light And...
Tried to install a ceiling fan to replace a dimming light chandelier.......light on fan and fan itself works but only by the pull chains....it will not turn off or on by the wall switch that controlled the...
Trip the breaker and verify that the fan/light will not operate. If tripping the breaker kills the circuit and flipping the wall switch would not, the switch is probably bypassed. Place the wall switch to "off" with the breaker tripped to the "off" position as well. Gain access to your wiring connections at the fan. Look for a single (black) wire that is not connected. This should be your hot return from the wall switch Make your fan/light connections to this wire. (Are you sure that the ground wire that you connected is a ground? If it is, it should be bare copper with no insulation). Your white (neutral) connection to the three white wires should be fine. If you don't find a single wire in the ceiling box, call on an electrician. Regards --WoobieDog--
Jul 07, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Can't control light at switch
It is wired so that you control the light with the remote. You cannot have it both ways. You either control it with the wall switch or the remote. Once you kill the power to the receiver by turning off power at the wall switch, you are only applying power to the receiver when you turn power back on. You are not supplying power to the light. You then must turn on the light with the remote. This is the purpose of a remote fan/light control. You could rewire it to control the light with the switch and only control the fan with the remote if you wish, but as you have it now, it is working correctly.
Jul 01, 2009 | Hunter 27185 Remote Control
Control fan/light separately, with only two wires
They are available at Home Depot and Lowes. Hunter makes a wall mounter dimmer that will control the lights and fan speed separately. There is a receiving unit that mounts above the fan to the house wires on one side and the others connect to the fan.
The two hots you mentioned should be a black one and a blue one. The blue is for the lights; the black the fan. Ground everything you can to boxes, etc, if the house is only a two wire system without a ground.
I believe that remote wall switch and receiver runs close to $40.
Sirwriter
Apr 22, 2009 | Slider Lutron: Dual Fan Control / Light...
Dryers Logo
421 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
