Question about Electrical Supplies
Briggs & Stratton 135212/0129 - Homelite HL2500
I have a Briggs & Stratton 135212/0129 engine on a Homelite HL2500 generator. I have no idea where to start with the various settings. After monkeying with it for 2 hours I managed to get it to idle consistently. I let it run for about 20 minutes but it was not turning enough RPM to produce any power. When I try adjusting the RPM with the fixed throttle adjustment it dies when I increase the RPM. What is the initial setting for the ''non-adjustable'' idle screw? What is the initial setting for the throttle linkage? What is the run position for the throttle linkage? Any help would be appreciated. Thanks.
  • auduster Aug 02, 2009
    It is not the choke. The manual choke is in the run position and works properly.
    Sergeant:
  • 202 Answers
The choke should be in the off position when running. YOU put the choke on to start it then when it starts u turn it off. If the choke is on the engine will die when reving
Posted on Aug 02, 2009
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Crafsman 2400 watt generator star ok but only run for 45 sec.& it won't star again the motor is a briggs & stratton 5.0hp
I have a Craftsman Snow Blower with a Briggs & Stratton Engine. I had the same problem. I searched online and read a little bit about this run and stop problem. One solution was to put something over a piece of metal that separates the hot engine part from the other part of the other side of the engine. I used a piece of heat resistant cloth from Lowes in the plumping area where the torches are. It fit and worked. Engine keeps running. I ran it for over an hour last spring prior to storing it.
Nov 01, 2012 | Electrical Supplies
Neighbor has a Briggs & Stratton Elite Series 5550 generator. How do you remove the generator from the engine. Need to repair oil capacity switch inside.
Hello; The Briggs engine front case is shaped to accommodate the internal mounting of the Alternator section. A service manual for this model would be very helpful. I believe you need to dismantle the back of the Alternator where the outlets are and then the outer case with the stator windings in it. This will leave the rotor ( the long shaft with windings on it ) which will be attached to the output shaft of the engine by some coupling device the you must dismantle. John
Aug 15, 2011 | Briggs & Stratton Power Products 5,550...
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
I am trying to figuare out what type of oil to put in a Briggs & Stratton model 09415-0 generator
Hi b_fesperman,
Here is Briggs&Stratton's webpage with the oil specs for their engines: http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Engine%20Oil%20Recommendations/
Copy and paste the entire address into your browser and the information will open for you. Note that synthetic 5W30 can be used in all temps.
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Jun 08, 2011 | Briggs Stratton H7159 & Stratton® 5500,...
I have a Briggs & Stratton Automatic Home Generator 7 kW, Model# 40301. I had it installed by an electrician. Who also installed Briggs & Stratton Transfer Switch 50 Amp. The problem is the...
It sounds like the mains sense wire is disconected from the control panel or the run wire is not being cut by the aux contact on the transfer switch.
Is the transfer switch manual or motorised?
Feb 15, 2011 | Briggs Stratton 7,000 Watt Automatic Home...
I have a motor that has been taken apart, i have no idea how the carb linkage is supposed to go, do you
If you go to the Briggs & Stratton Website with your full engine No. you should be able to view an illustrated parts list for your engine that may give you the layout for the carb linkage.
Sep 21, 2010 | Briggs and Stratton 073001 2" Portable Gas...
No power output from Briggs & Stratton ProMax 7500E generator
You may have exciting field broken. Look for a fuse or wire break.
Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Electrical Supplies Logo
909 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
