Question about Sewing Machines
Bobbin won't wind the thread
I have a Brother CS-8072. The bobbin threader suddenly stopped working. How do I fix it? I can't figure out how to take the machine apart. It's all plastic, so I don't want to force it. Thanks!
  • 90 Answers
Open the machine there is a wrong black rubber that need to be replaced
Posted on Aug 03, 2009
I have a brother CS-8072 sewing machine and need help winding bobbin. I followed the instructions in the manual but it didn't work.
What were the results of your bobbin-winding attempt?
Make sure the thread path is correct for bobbin winding and that the thread is seated in the tensioner. Most machines, it is better to NOT wind fast--although your machine says the opposite (???).
It looks like your thread comes off the spool goes to the left, through a guide, down to the front of the tensioner and the doubles back to go behind the tensioner before going to the bobbin. (Looks the thread goes counter-clockwise in front of the tensioner, then doubles back and goes clockwise around the back of the tensioner.)
Also, the problem may have to do with the spool type you are using. Try a different thread and spool--AVOID old or bargain bin threads.
If you still have problems, there is a stand-alone bobbin winder (called Sidewinder) for about $30 that is helpful to have. (Verify it will work with your machine's bobbins!) It is great because you can wind bobbins without unthreading your machine and it saves wear and tear on your machine.
http://support.brother.com/g/b/manuallist.aspx?c=us&lang=en&prod=hf_cs8072eus&flang=English&type3=348&type2=69
Apr 28, 2017 | Brother Sewing Machines
Cs-8072 Red light
It's just a thought, but the red light will or should come on as soon as you push the bobbin winder in position to wind a bobbin. The red light should turn off when you push the bobbin winder back to the original position. I can't tell you how many times I have been dumbfounded after having done this. I hope this helps.
P ;)
Jun 03, 2014 | Brother CS-8072 Computerized Sewing...
Exterior Bobbin winder does not turn or wind a bobin? Model CS-8072
you will need to turn the speed to maxium then press the start button. I attached a site that has your manual and shows great pictures of how to wind a bobbin.
brother model CS-8072
Mar 15, 2011 | Brother Sewing Machines
My machine is suddenly locking up and the thread is getting tangled underneath the fabric.
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 23, 2011 | Brother CS-8072 Computerized Sewing...
How do I wind the bobbin on a Brother sewing machine Model CS-8072?
Go to brother.com and get a manual download for free, make a copy and you will learn all about your machine
Jul 20, 2010 | Brother CS-8072 Computerized Sewing...
Bobbin thread won't engage.
The bobbin case is not in the shuttle.
Raise the needle to it's highest position.
Lift the lever on the back of the bobbin case and hold it open as you insert the case into the shuttle; arm on the case pointing up. You may have to turn a bit to the left or right - it will click when in place.
Mar 20, 2010 | Brother CS-8072 Computerized Sewing...
After following instructions on winding the bobbin for the fast bobbin winding system, the bobbin is not threading
If the bobbin spool is spinning, it will thread.
Take the end of the thread through one of the little holes in the side of the bobbin spool and pull out about 8" of thread. Hold onto it as the bobbin begins to spin.
After the thread has wound 5 - 6 turns, stop the machine and cut off the thread end. Continue the winding process.
Mar 14, 2010 | Brother CS-6000
Threading bobbin on singer stylist 522
To wind a bobbin put the cotton reel on the top pin, take the thread to the left and round the little wheel and back to the bobbin that should be on the winder, wind the thread round a few times to take a grip, release the stop motion in the balance wheel, turn the winder button so the winder moves to the balance wheel and press on the foot control slowly.
When you put the bobbin in the bobbin case make sure it turns anti clockwise.
Jun 27, 2009 | Brother CS-8072 Computerized Sewing...
The thread off the bobbin gets jammed everytime. How can I fix th
It sounds like you are not threading the machine properly. The best way is to make sure the presser foot is in the up position. This keeps the tension disc open and the thread slides into the tension easier. Also make sure you have the bobbin in and threaded correctly into the bobbin case.
Mar 01, 2009 | Brother CS-8072 Computerized Sewing...
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
119 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
