My ML2010 printer turns on, takes paper, but stops halfway (blank
My ML2010 printer turns on, heats up, takes paper but stops delivery half way through the page. Page is blank and red LED comes on. I have 2 of these printers and I tried switching the toner cartridge but it made no difference. Help!
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; Replace paper pick up roller and feed roller.
Posted on Aug 02, 2009
I have a samsung CLX 3175 FW printer. Paper jams halfway through print cycle. Nothing in mech to stop - appears to be limit switch fault? If you turn the printer off and on it clears paper
The limit switches are just flags that block or unblock photo sensors. Try blowing the printer out with some canned air, paper dust on these sensors is a common cause of these problems.
Jun 23, 2010 | Samsung CLX-3175FW Multifunction Laser...
Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Apr 27, 2010 | Samsung ML 2010 Laser Printer
Print job stops halfway
I have the same problem - reading elsewhere - people talk of an exit sensor failing - that would figure - because one minute it was perfect the next it prints just half way and stops the print in the exit jaws - surely somebody knows the exact solution to this issue.
Any help with ideas about this problem ?
Greg McC
Dec 18, 2009 | Office Equipment & Supplies
Samsung ML2010 printing blank pages after toner replaced
Reputable or not, every once in a while you get a bad one (even originals). It's obviously defective. Return for a replacement
May 19, 2009 | Samsung ML 2010 Laser Printer
When faxing or scanning the paper stops feeding
Thank you for contacting Fixya Support.
Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........
Good Luck......
May 06, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Paper Jam
If it truly stops halfway then it must be obstructed by seomthing. If it only gets a short way past the pick up roller then it may be something else. A little trick for removing obstructions is to fold your paper in half or even a quarter so it is much thicker and stronger and try to feed that through. This can push through any obstructions (assuming they aren't too big). If it still gets stuck see if you can manually turn the main gear found to the side of the carriage and try to push the paper through that way (hence pushing through your obstruction). If your paper feeds through fine doing this then you may have another issue.
Good Luck.
Please rate my advice, good or bad.
Feb 03, 2008 | Lexmark All-In-One Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
180 people viewed this question
jasbo
jasbo
