Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Menu Screen pops up, try to exit and goes to video 1
TV doesnt respond to the remote. When I turn on manually, the cable works for a minute then menu screen comes up. When I manually press the (-)volume button to exit it starts scrolling between TV, Video 1, 2, 3, 4.I've unplugged cable box and TV and plugged back in and its still doing it.
TV is a SONY Trinitron KV-27FS100
  • 167 Answers
This could be a stuck button on the front control panel or a bad solder connection on one of the switches on the front control panel.
Posted on Aug 03, 2009
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
My SONY KV32FS13 DO NOT HAVE IMAGEN ON THE SCREEN NO GET ANY CHANNEL OF TV OR CABLE ONLY WORK WITH DVD EVERY TIME WHEN TURN ON COME OUT NO SIGNAL.
Try pressing Tv/Video on the remote control and see if it doesn't switch input modes. If it doesn't, follow these steps:
1) Press the menu button
2) Navigate over to Channel Setup
3) Move down to Video Label and select it
4) Make sure none of the video inputs are labeled "SKIP". If so then do the following
5) Highlight the input labeled "SKIP" and select it
6) Use the up and down arrows and you should see a different name for the input. This will enable the selected input to be used.
7) Exit the menu by pushing the menu button on the remote.
8) Press Tv/Video on the remote and you should see the other stuff (cable, vcr, xbox, etc.).
Aug 15, 2010 | Sony KV-32FS13 TV
Stuck on menu screen
Try connecting the TV directly to a different wall outlet and check. Try resetting the TV to the factory settings. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Philips 42PF9431D/37 TV
Menu pops up while tv is on
Isolate the problem by removing the batteries from the remote. If the problem goes away replace the remote: "CHEAP" .
If the problem does not go away, the problem is in the TV, repair the TV "EXPENSIVE" !
Aug 28, 2009 | Televison & Video
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Mitsubishi VS-5003R TV is on but won't connect to cable.
this is the service menu , try to exit out of it , if you can't turn off power on both cable box and tv then unplug both of them and disconnect the cable from the tv , leave it unplugged for at least 10 min , then try it again , if it still does it then the crystal that is connected to the IR sensor and EEPROM IC needs to be replaced as the IR sensor should be also replaced
hope it comes out of that!, if not we can try to set the menu settings for it being like a clock and #1 on the remote to exit the menu
let me know what happens , thanks,
electech
Oct 21, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Picture Refresh Problem
Used Panasonic Concierge Chat and they had me do this:
press volume down on the TV (not the remote) and then press menu on the remote for 10-15 seconds to bring up a check screen. After that, unplugged TV for one minute. Plug TV back in and set up for Home. Can exit out of the rest of the set up. So far so good......this was happening only periodically for me, so we will have to see if it works. I was also having to go to TV Video and select Component 1 (cable for me) every time I turned on the TV, but the above action fixed that. Now it goes to the input that was on when the tv was last turned off. Concierge is free. Very cool.
Jun 09, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Programming a vcr
How can t I get the pop up screen when I apply menu. When I press menu nothing appends. I have the illico box for HD and had the videotron tech install it so I can recorded but since the menu does not work I cannot set the time or anything else on it.
Thanks
Gilles T Garceau
Dec 11, 2007 | JVC HR-A592U S-VHS VCR
Unwanted black rectangle on the TV screen
I'm not sure what type of TV you are using,, but most all Large Screens have a reset button someplace. You should be able to reset the TV and fix the problem. Its not the remote, making the image appear, but a command from it was misinterpeted. Sometimes turning the set off will work, but most often it needs to be reset.
EXCEPTION... if you are using a cable box. Disconnect it from power, wait 1 minute and then see if the problem exists. If the cable box is on even with the DVD you may still have this issue. Please reset the cable, and if that doesn't work, reset the TV.
Thanks! //D
Dec 02, 2007 | Philips PM435S Remote Control
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
133 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
