Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Hi, bottom of pool is clean that morning, I run the pump and at the end of the day there will be quite a bit of dirt and what looks like tiny bugs on the bottom. It's like the pump is passing stuff right through it. I took the diverter valve apart and the rubber gasket looks good. Harry B.
  • 1,305 Answers
It may be the filter unit. If it's a DE filter, it's possible that one of the cartridges inside has a hole, rip, tear and the debris is getting back in... is it cloudy at all? Make sure that the diverter top is put back on in the exact same location as you had it before...
Posted on Aug 06, 2009
How do I vacuum my index pool
Even with an "upgraded" pump, it still doesn't provide enough suction to do a good job. They are just a better than non upgraded 'toy'! But... Take your vacuum hose with the vacuum head attached and one end connected to your telescopic pole and send it to the bottom of the pool. Then slowly feed the rest of the hose pushing water into the hose until you reach the opposite end. Water should come out of the other end! If it does not, you did not prime the hose correctly. Try it again this time push deeper into the water beating the hose slowly pushing the water up into the hose at the surface level. Once you have water coming out of the other end you plug it into your suction port. Turn on the pump and now you have section at the other end of the hose, that the vacuum head. Now just vacuum the bottom of the pool, as you would vacuum your carpet in your home.
all of that dirt, sand, silt, and other debris, will end up in your filter element. You will have to clean it, if not replace it.
Feb 07, 2015 | Intex Ultra Metal Frame Pool w/ Upgraded...
Pump wont turn on
make sure heat maintain is off if ok new pump
Apr 04, 2014 | Pentair Pool & Spa
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
We opened the pool on Monday and on the bottom was a lot of either fine dirt or sand. We got everything running and it was running fine until Tuesday afternoon. On Tuesday morning I stirred all the stuff...
Have you backwashed your pool filter? It could be that the sand is dirty or a line is clogged, causing the filter to lack pressure. Make sure that your multi-port valve is set to the filter position. It could be a broken lateral or a busted multi-port valve that is causing it not to work, but if it was working before you brushed the bottom and sides, I doubt this is the problem. Before you try any extensive repairs, I would backwash several times and possibly even replace the sand.
May 12, 2011 | Hayward SAND FILTER, PRO SERIES
Vac gets stuck in deep end and can't get to shallow end
What type of pool do you have? These specific pool cleaners are made for flat bottomed above ground pools. They are not made to move from deep end to shallow end. If you are using this on an in ground pool that has both shallow and deep or a dished above ground pool, you are not going to get accurate cleaning.
Mar 06, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
I have a Challenger 3/4 HP Pool pump and I dont have a good seal at the motor. What is the proper assembly? Do the two ceramic surfaces face each other, or does one of the ceramic sides face the motor?
Yes the two ceramic surfaces face each other. That is what actually creates the seal and where the friction takes place. Also need to keep these surfaces clean and free of any dirt or grease while assembling. If you tried running them the other way, or even scuffed up the surfaces, you'll need to replace that seal again. Make sure when you install them that the half with the white surface is mounted straight and even, clean out the area where the old came out, and use a tiny bit of pool lube around the rubber so it pops in nice and even. Some people use RTV sealant for this and then later it is sealed into place better, but it's not necessary. When you install the other half with the spring onto the motor shaft also put the tiniest bit of pool lube on the inner rubber part so it's slips onto the shaft, but do not get it on the ceramic.
Sep 21, 2010 | RTO ALADDIN GO-KIT #5 PAC FAB CHALLENGER...
Cloudy brown dirt getting in my pool from sand pump
The dirt you are getting is most likely from the air, dirt and dust present in rainwater and the small amounts present on human bodies. It is settling out and going to the bottom. I recomend a vacuum attachment that connects to your pump/filter to keep this cleaned out. Basically it "plugs In" to the outlet on the pool and will get all that out for you.
Aug 11, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
61 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
