Question about Ingersoll Rand SS3J5.5GB Wb Ir Portable Air Compressor 5.5HP Briggs & Stratton Gasoline Engine 8 Gal Twin k Single Stage Wheelbarrow
Briggs & Stratton 135212/0129
I have this engine on a Homelite HL2500 generator. I have no idea where to start with the various settings. After monkeying with it for 2 hours I managed to get it to idle consistently. I let it run for about 20 minutes but it was not turning enough RPM to produce any power. When I try adjusting the RPM with the fixed throttle adjustment it dies when I increase the RPM. What is the initial setting for the "non-adjustable" idle screw? What is the initial setting for the throttle linkage? What is the run position for the throttle linkage? Any help would be appreciated. Thanks.
4 Suggested Answers
  • 1388 Answers
SOURCE: starting problem/turning self off
Follow the copper airline that leads from the compressor to the tank and you will find the pilot valve. This brass valve controls the pressure setting and also controls the engine. There is a small flip lever on top of the pilot valve that unloads the compressor for easy starting when there is pressure in the tank. Raise the lever straight up for start and lay to side for normal run cycle. When the compressor fills tank to set level, the pilot valve pops and idles the engine. If engine stalls raise idle by turning the idle screw clockwise at the carb. The arm that you see under the tank is the governor control arm. To increase the engine speed when pumping turn speed control screw counter clockwise. Sometimes the throtle control cable must be adjusted by loosening the clamp that holds the cable (black cable) at the engine and pulling the cable back away from the clamp and re-clamp. Hope this helps, good luck.
Posted on Dec 28, 2008
  • 41 Answers
SOURCE: I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Posted on Sep 28, 2009
Testimonial: "Cool!!Thanks!I finally got a "page" on pressure switch. Its not in the regular owners manual. It was like pulling teeth,& had to get it from GRAINGER"
  • 2527 Answers
SOURCE: i have an old ingersoll rand air compresor dxl 900
sorry
Posted on Jan 15, 2011
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
My 26 year old Briggs & Stratton 8 hp engine (on a
Did you remember to "wind" the cord when you replaced it. They normally have a spring type of set up that you have to wind before you bolt everything together.
Jun 30, 2011 | Briggs & Stratton Electrical Supplies
Briggs & Stratton 12KW Model 040229 LPG Generator. 96 Volts @ the 120 Volts outlet, When I turn the house 2 Ton AC voltage increase to 106 Volts.
Can you manually adjust the voltage on the generator without load?? If you have 120/240 60hz output on it and you are not overloading the unit (amperage), then it may be as simple as adjusting whats called your gain setting for your voltage regulator. Obviously you are seeing what happens when it is set too low. Trying raising that setting until it becomes unstable then back it off. Unstable meaning voltage starts jumping all over.
Jun 27, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
I have a motor that has been taken apart, i have no idea how the carb linkage is supposed to go, do you
If you go to the Briggs & Stratton Website with your full engine No. you should be able to view an illustrated parts list for your engine that may give you the layout for the carb linkage.
Sep 21, 2010 | Briggs and Stratton 073001 2" Portable Gas...
No power output from Briggs & Stratton ProMax 7500E generator
You may have exciting field broken. Look for a fuse or wire break.
Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton 135212/0129 - Homelite HL2500
the choke should be in the off position when running. YOU put the choke on to start it then when it starts u turn it off. If the choke is on the engine will die when reving
Aug 02, 2009 | Electrical Supplies
Ingersoll Rand  SS3J5.5GB Wb Ir Portable Air Compressor 5.5HP Briggs & Stratton Gasoline Engine 8 Gal Twin k Single Stage Wheelbarrow  Logo
191 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
