Question about Canon PIXMA iP1600 Printer
Cannon pixma 1600
Says paper jam and there is none. seems to be a regular problem. is there a fix for it?
Posted on Jan 11, 2008
I took the entire top cover off, after removing 3 screws and a bit of pushing & prying where I found 6 slots scattered about the case. The slots are inside small recesses about 1/4 x 1/2 inch and each has a small arrowhead embossed into the plastic pointing to the slot. I couldn’t figure out the problem at this point, so I hooked it up to my computer again, still with the cover off. With some finagling, I was able to get a sheet to feed (by trying various placements of the sheet with respect to the little white plastic fingers that appear to hold the paper back from the feed rollers; I also had to experiment just a bit with the timing as to when to place the paper into the feed position). I repeated this process a few times till I noticed that the fingers were now releasing on their own (such that they would allow a sheet to fall into the feed rollers). I then loaded a single sheet (this time before initiating the print command) and it fed and printed all on its own. I repeated this a few times and then ran a two-page print command; it again fed okay. I think it's okay now, probably until I put the cover back on; then it'll probably fail again- or maybe sooner. The rather difficult step of removing the cover is probably not necessary to try my method, but it does make the mechanism easier to see. Without removing the cover, try to see the two little white plastic fingers against which the paper rests when you look inside from the top-rear of the printer. The black feed rollers are just forward of these. The single sheet to be printed needs to get ahead of those fingers & between those rollers.
I had the same problem, and found that the sheet feeder mechanism was intermittent. The problem seems to be that the lubricating grease inside the mechanism.(white nylon round thing with gears on it) becomes too slippery and stops picking up the activating arm which allows the cam unit to move to kick the top sheet of paper into the rubber feed wheel.
The repair was extremely difficult because it involved taking most of the printer apart to get to the ink pump/sheet feeder mechanism.(white nylon round thing with gears on it), and then I tried quite a few lubricants (including no lubricant at all) but none of these worked reliably. Finally I tried a dab of automotive wheel bearing grease (it feels like glue), and this worked perfectly. I have had no more paper jam errors and no miss-feeds in about 7months of everyday use.
Posted on Jan 09, 2008
Cannon IR 1600 Rec paper jam any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Paper jam in Cannon Printer
open top if you can do it if you can not softly pull paper if still does ask person at store and if STILL! not work return it.
Jun 20, 2013 | Office Equipment & Supplies
My cannon pixma ip 1600 keeps giving an error
Hello there
You may not see a paper jam, so this is worth trying.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Canon PIXMA iP1600 Printer
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
Dec 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
HOW TO LOAD MY 1600 CANNON PIXMA PRINTER,sh,39298,430,12,.html might help
Mar 04, 2008 | Canon PIXMA iP1600 Printer
Cannon mp780 paper pulls to right hand side and jams everry time
printer loading tray have problem /something struck at left side of tray /check if something/if none / sometime it connot be seen its hide five cents .
clean also the incoming roller and outgoing rooler w/cotton tips w/ rubbing alcohol. test the printer.
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
141 people viewed this question
old marine
old marine
