Question about Tomtom GO 910 GPS Receiver
How do i turn off my tomtom screensaver?
My tomtom one keeps showing a screensaver after about 10mins and i want to know how to turn the screensaver off
  • Shawn S May 11, 2010
    When exactly does the screensaver come on? while you are driving? while you are just sitting idle with no destination? please clarify exactly when it happens.
I have plugged my tomtom into a 110adapter to recharge how do i know when charging is complete ? device is off.
approx. 3hrs should be enough if not when you turn it on it should show you progress of charging.
Oct 17, 2015 | Tomtom GPS
I have formated my tomtom one and know it will not start with out showing a flashing disk and a x
Probably the last update was not applied correctly or it was corrupted.
Please, try this:
1) Place the GPS on the cradle connected to the computer and start TomTom Home.
2) Turn the GPS on and connect it to the computer.
3) Erase the downloaded software (using the "remove items" from the TomTom home software)
4) Choose "disconenct device" from the drop down menu of TomTom2_bing.gif Home
after the GPS powers down and restarts, press the RESET button on the button (keep it pressed for 7 seconds)
5) Repeat setps 1-2 from above. When TomTom Home detects your GPS, it will offer to update it. If it doesn't, choose "update device" from the TomTom Home buttons
Please, report back if you need further assistance
Mar 28, 2010 | Tomtom One XL GPS Receiver
Home location keeps showing a different location. reloaded home address still showing a different location.
On the TomTom One, this is impossible unless you have several maps.
Each time you switch to another Map, the preferences such as Favorites and Home addresses only apply to that specific map.
Let me know if it helps or let me know exactly what you are doing to change and set your Home address.
(hint: Change preferences -> Change Home location ?)
Jan 06, 2010 | Tomtom ONE XL GPS
IT is a xxl 530 s tomtom. Do you keep the unit
While in drive view, tap the screen on the blue status bar, on the GPS signal strength. A new screen appears showing the battery charge level at the top right corner.
Dec 29, 2009 | Tomtom ONE XL GPS
Nokia 7610 screen problem
try this type *#7370#
Dec 31, 2008 | Nokia 7610
Nokia 7610 displays white screen after screensaver timeout
format: press green button, asterisk, and the number 3. press this 3 button all together then press power on. don't let go if u see formatting release it. then wait until the formatting is finish after that its ready to use.
Screen saver
Most likely the demo script in the \script directory of your TT is named "salesdemo.script". A script by this name is run automatically after a certain time. Just rename it to "demo.script". Problem solved.
Jun 06, 2008 | Tomtom ONE 3rd Edition GPS
TomTom GO 910 - screensaver?
try this it does take a while to do.
STEP 1
Connect your TomTom to your computer1.gif via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup1.gif you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Dec 27, 2007 | Tomtom GO 910 GPS Receiver
TOMTOM ONE
Hello you should be able to contact them at one of these websites
https://www.shop.tomtomrecords.com/contactUs.hg
http://www.tomtom.com/support/support.php?ID=2
I would try the second one first.
Good Luck - Dr. Know
Dec 20, 2007 | Tomtom ONE GPS Receiver
Tomtom GO 910 GPS Receiver Logo
1,221 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
