Question about Jenn-Air Cooktops
Downdraft comes on when front left burner is turned on. Just rented house, did it the 1st time I used the cooktop. several times after the downdraft worked independently and now (apporx 4th time) downdraft comes on when burner is turned on and won't respond to independent switch.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 27 Answers
Typically the Jenn-Air has a grill on the left hand side and the fan is suppose to come on when that burner is turned on.
Posted on Aug 04, 2009
  • akdewey
    akdewey Jan 07, 2012
    If you put regular burner on left hand side, fan doesn't automatically come on. Only if grill burner is placed on left hand side (can't place on right hand side), will fan come on automatically, sucking a good amount of heat away from the grill. Ridiculous. I don't know of any safety issue this is circumventing. If no burner at all is in place on left hand side, fan automatically comes on. Maybe this is good to **** out unburned gas and the mornoic user won't blow up his kitchen. But guess what! Remove burner from right hand side, tun knob, and fan doesn't automatically come on. Smell the gas! ***** suffocates and/or blows up his house.
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
I need a left front burner for a CP 220B Jenn Air electric downdraft cooktop: Serial no 069760DM. I also need a new blower motor, I think. Possible???
This is the first result I found; it may not have the best price:
http://www.appliancepartspros.com/jenn-air-range-cooktop-oven-burner.html
The site also lists blower motors, but be sure to verify that the motor is defective before ordering; they are very expensive.
Jan 17, 2017 | Cooktops
How to replace a fuse?
It is fused through the house breaker box.
Mar 15, 2017 | GE Select-Top 30" Modular Downdraft...
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
Downdraft cover and grill grates
i bought mine new from HD. Neither the dd cover nor grill grates have bushings on them. however thats a good idea.
Dec 31, 2008 | Jenn-Air JGD8345 Gas Cooktop
Jammed knob on Gaggenau cooktop
It looks like the gas valve for FR burner has to be replaced. Very unusual for Gaggenau gas cooktops.
Nov 18, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
Downdraft Slide-In Range
I have the radiant cooktop (i.e., glass top) version of this range. I've had this same problem since I first purchased this unit. I wondered why no one answered this question, as I check back to see from time to time. I finally contacted Jenn-Air's online support. My conversation was as follows (I'm not entirely sure that the tech support knew what she was talking about, but here you go anyway):
message.gif?p_db_name=whirlpool Cidalia C: Hi, my name is Cidalia C. How may I help you?
message.gif?p_db_name=whirlpool You: Hello!
message.gif?p_db_name=whirlpool You: I have a question regarding my "Downdraft Radiant Cooktop"
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air today with your inquiry. What is your question please?
message.gif?p_db_name=whirlpool You: None of my burners can simmer-- no matter what the setting, they will boil water!
message.gif?p_db_name=whirlpool You: Is there an adjustment that can be made to attenuate the heat?
message.gif?p_db_name=whirlpool Cidalia C: What is the model number of your cook top please
message.gif?p_db_name=whirlpool You: JED8430ADB
message.gif?p_db_name=whirlpool Cidalia C: Thank you. In looking at your burner configuration, the smallest wattage on your unit is 1200. And, unfortunately, there is no way to get a small wattage for your burners. We apologize for the inconvenience.
message.gif?p_db_name=whirlpool You: Yes, but the dials are supposed to prevent the full 1200 watts from reaching the burner unless it's on maximum heat, correct?
message.gif?p_db_name=whirlpool Cidalia C: Yes, but the burners do not get low enough to be considered simmer burners.
message.gif?p_db_name=whirlpool Cidalia C: Did you have any other questions or concerns today?
message.gif?p_db_name=whirlpool You: I suppose not.
message.gif?p_db_name=whirlpool Cidalia C: Thank you for contacting Jenn-Air. Have a good day!
Jul 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Cooktops Logo
593 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
