Question about Home
I have an Eljer jet bathtub with a smell to the water when we bat
I have an Eljer jet bathtub. Problem is I do not think the hoses in the jets drain well and the water has a smell when we take a bath. I have tried running just hot water with soap and some bleach to kill germs but the smell remains.
    Scholar:
  • 80 Answers
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Posted on Aug 19, 2009
Where does the hose on the on off switch on whirlpool madison is the model go to. It came unhooked and dont
There should be a control box on or near the pump motor. Look for a small hose connection on the control and attach hose there.
Hope this helps.
Bob
May 01, 2014 | Eljer Madison Eight Jet Whirlpool
How do I get bad smell and crud out of jacuzzi jets
If you are experiencing a "smell" coming out of the water when you use the tub then you should use one of the products that are made for cleaning jetted tubs pipes.
Here is a link to a site that carries those items. These will get rid of the nasty smell and flecks of bacteria when you use the tub too.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Rod
US Parts Center
Mar 15, 2014 | Home
I need to know how to clean the jets in our eljer spa tub
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Oct 04, 2013 | Eljer Home
What type of aromatherapy products can I add to my Eljer Stratus SILENTJET
any aromatherapy products can be used in jetted bathtubs.
US Parts Center
Apr 21, 2013 | Eljer Stratus SILENTJET WP 6x36
Makes noise but jets do not work
Is intake clogged? sounds like impeller has come loose from pump if not.Take a garden hose and feed water back from a jet(closing/plugging others) to see if it flows back out intake checking for obstuctions. Are jets all the way open and water level well above intake?
Oct 04, 2010 | American Standard Cambridge 5' Americast...
Jacuzzi jets smell like rotten eggs when turned on.
Need to run some cleaner through jets to clean out old water and mildew.
May 09, 2010 | Home
Eljer jetted tub on and off switch will not work
It may seem like a dumb answer but check the ground fault outlet or breaker. Then make sure there is enough water in the tub. It should be a few inches over the jets.
Mar 23, 2010 | Eljer Home
Eljer corner whirlpool is leaking around jets. What is the best way to stop it?
You need to remove jets check for cracking if so buy new jet if not cleanup and use a 100% clear silicone to re-install
Nov 14, 2009 | Home
Tub motor comes on but no jets . tubis 2 yr s old
You can try checking to make sure all the little vaccum hoses are still connected.
Oct 13, 2009 | Eljer Home
Smell coming from jacuzzi whirpool tub
the jet covers normally unscrew counter clock wise .As far as the smell goes it could be clumps of old hair after time the old hair usually causes a pretty bad smell.Try snaking the drain.This might help.
Feb 01, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Home Logo
390 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
